        1st March February 2012
	    Latest post 02-01-2011 6:43 AM by Chris . 7 replies.
								    |  01-31-2011 5:23 PM |  |
									                 Chris
 Joined on 03-19-2010Corbridge, UKPosts 353 |
										    Well i proudly shot of down to London today to pick up my Beovision 26 HD ready, and ended up getting home and finding out it was a Beocentre 23(with DAB module but no HDMI slot). After you finish laughing here's a question. It does have a DVI connection at the back, can i connect this to SKY HD and watch the appropriate signal? I am aware i would need to run the audio independently. Please help A Beovision 10-40 in black and red fret on order, Beo4, Beo6, many A8's, a pair of white and yellow Form 2's, Beocom 4, 28 inch Avant RF DVD, Apple TV and a wife that loves this stuff as much as i do!  |  |
									                 9 LEEJoined on 02-14-2007Moderator - UK      Posts 5,223 |
										    Yes, you can use the DVI for the HD signal and do the Audio seperately.  However, having a DVI socket doesn't always mean there's something actually behind it.  Go into the DTV settings and see if it gives you the option of DVI-I... Lee PS - I do hope you knocked the seller down on price !! BeoWorld - Everything Bang & Olufsen |  |
										    You can go into the setup menu and change those you know!  Just highlight them, then scroll through the options. In fact, try STB - preferably STB(DTV) if it gives the option. Lee BeoWorld - Everything Bang & Olufsen |  |
									                 ViennaJoined on 08-15-2008make an educated guessPosts 712 |
										    Keep in mind - early models of the 6-23/26 were NOT HD READY!
 Without an upgrade with the HD-ready kit - only non HDCP (non copy protected) video content,
 e.g pictures from your computer can be displayed - but NOTHING DELIVERED by a  BluDisc or a HD-Cable/Sat receiver ...
 Add "PC" to your Beo4 "LIST" and try to access the DVI-Input - it should be an DVI-Integrated input and
 should handle VGA as well as DVI signals.
 4 digit Type# or the Ser# of your TV would help  ... |  |
									                 Chris
										    Sorted out and refund due shortly. Thank you to everyone for doing the research etc. Picking up an HD model on the way home, and its a 26!!!   Don't trust old grannies A Beovision 10-40 in black and red fret on order, Beo4, Beo6, many A8's, a pair of white and yellow Form 2's, Beocom 4, 28 inch Avant RF DVD, Apple TV and a wife that loves this stuff as much as i do!  |  |
						     Page 1 of 1 (8 items)  |
