1st March February 2012
Latest post 10-10-2011 3:58 AM by elephant. 38 replies.
11-14-2007 3:13 PM
YannChris
- Joined on 04-16-2007
- Larmor-Plage, France
- Posts 276
Hi Andy, I tried this command with Beolink 1000 MKI and MKII and nothing happened. Yann.
Ne pas s'en faire et boire frais!
Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Andy, I have just tried it with a MK1. It does not do a thing. My BS3000 just stays in Standby. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Alex
- Bath & Cardiff, UK
- Posts 2,990
Wastes battery?
Although it does seem to put the BLink 1000 in a different mode. Not video mode or audio mode. Interesting...
Weekly top artists:
Craig
- Posts 4,855
Well the remote does do something, just not sure what. Just had a look using the camera on my mobile phone. Craig
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
You're on the right track Alex. A little clue. Shift, Phono, followed by a number of one or two digits (up to 16) Takes three seconds to have an effect. Peter should know, as should Keith Saunders, Keith (Frank Rizzo) and Craig after our recent communications.
Craig
- Posts 4,855
Andy, you have me totally lost. We were talking about using Shift, Link to operate an LC2. Just tried Shift, Phono and a number from 1 to 16. Nothing, although if it was for an LC2 you can only use 0 to 9 for the different light levels. Craig
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
jandyt:Nothing to do with lights then. Any minute now, Puncher is going to come on here and give me a bollocking for poaching Wed thred posters!
Consider yourself bollocked! BTW - it's not a battery health check is it?? - (pure guess, I've never used one).
Jandyt
- Posts 13,004
Craig
- Posts 4,855
Do you need a Datalinked Beogram for this to work? If you do then that is why it does not do anything on my system. Craig
Jandyt
- Posts 13,004
No I'm enjoying this
Craig
- Posts 4,855
Is it CD2? You have this on a Beo4, and Shift, CD on a BL1000 is DVD. Craig
Craig
- Posts 4,855
When you look at the end of a remote through you mobile phone camera you can see it light up, the camera can see the IR beams. Craig
Craig
- Posts 4,855
It has something to do with that Speaker switch box thingy you got on Ebay Craig
Craig
- Posts 4,855
Got it, that is how you select which pair of speakers you want to listen to. If I remember correctly you connect up to 16 pairs of speakers. Craig
Jandyt
- Posts 13,004
