Latest post 01-29-2010 2:06 PM by Kim Hubbard. 4 replies.
Page 1 of 1 (5 items)
  • 01-23-2010 6:38 PM
    LS6000 tv connected to DVD1 question about connecting to Beosystem5000
    Have LS6000 tv connected to DVD1 via 21pin (scart)
    have then run phono cable from Audio Phono Output sockets L&R on DVD1 to Phono Inputs (Tape 2) on Beomaster 5000
    further info...
    Tape 1 din used for IPOD/IPHONE works fine, din connected
    Newly repaired (thanks to forum thread) CD50 works fine, din connected
    Beogram 5000 works fine, also
    all controlled through the Master Control, which also I beleive work fine
    result the DVD output (sound) is heard for only 60 seconds (through the Beovox S55 Speakers connected to the Beomaster 5000) and the system then goes into stand by... why?, should I be connecting into the din scocket of the Beomaster 5000 Tape 2 and if so why? (haven't got cable to test)
    WHY!?...not after 5.1 sound arround but a fuller retro/vintage volume of sound which i get for only 60 seconds
    have I a mute/standby problem? tape 2 related or is the 21 pin(scart)/DVD1 fighting for some reason
  • 01-24-2010 6:08 AM In reply to
    Re: LS6000 tv connected to DVD1 question about connecting to Beosystem5000
    Update
    Today I'm playing an audio CD in the DVD with the same above cables connected and Whistle it works, the TV shows the track information and the amp played all tracks. But the DVD sound cuts after 60 seconds Super Angry
  • 01-24-2010 1:40 PM In reply to
    I do not know what the issue is: whether there is a problem with the cable, or the phono connections; or whether there is a design consideration you and I do not know about ... but just to help eliminate things, why not unplug the TAPE 1 DIN and try its phono plugs with the DVD1?
    Also how long is the audio cable from the DVD1 to the BeoMaster ? And do you have a spare cable you could use to check the link-up with, or another combination of units to check the cable with ...
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-24-2010 6:27 PM In reply to
    Thanks again elephant for being on my case, it's always a worry that when you have posted a question you get no responce
    I am awaiting a new cable from B&O, twin phono (for DVD) to 7pin din (for tape1 or 2 socket). I didn't/don't think it's cable related because the Audio CD plays fine but like you thought to eliminate this possibility. regards the 'design consideration you and I do not know about' who knows I hope not.
    Any other thought are welcome.
    thanks again
  • 01-29-2010 2:06 PM In reply to
    it was the cable, twin phone to twin phono or the phono sockets in the beomaster Angry... I changed cable to twin phono to 7pin din and all sound out puts from the DVD1, Movie audio and CD audio works fine, thanks again elephant
