Have LS6000 tv connected to DVD1 via 21pin (scart)
have then run phono cable from Audio Phono Output sockets L&R on DVD1 to Phono Inputs (Tape 2) on Beomaster 5000
further info...
Tape 1 din used for IPOD/IPHONE works fine, din connected
Newly repaired (thanks to forum thread) CD50 works fine, din connected
Beogram 5000 works fine, also
all controlled through the Master Control, which also I beleive work fine
result the DVD output (sound) is heard for only 60 seconds (through the Beovox S55 Speakers connected to the Beomaster 5000) and the system then goes into stand by... why?, should I be connecting into the din scocket of the Beomaster 5000 Tape 2 and if so why? (haven't got cable to test)
WHY!?...not after 5.1 sound arround but a fuller retro/vintage volume of sound which i get for only 60 seconds
have I a mute/standby problem? tape 2 related or is the 21 pin(scart)/DVD1 fighting for some reason
