Latest post 10-16-2008 10:22 AM by h1npw. 2 replies.
Page 1 of 1 (3 items)
  • 10-15-2008 7:39 PM
    • ducha
    • Not Ranked
    • Joined on 01-04-2008
    • Wisconsin, US
    • Posts 77
    Cleaning my 6500
    Hello everyone,
    I'm wondering what I should use to clean the shiny surfaces of my Beosystem 6500. Also, is there any kind of polish I can use on the metal that won't cause damage to the finish?
    Thanks in advance,
    Aaron
  • 10-16-2008 2:20 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Cleaning my 6500
    Hi Aaron,
                 baby wipes followed immediately with a soft cloth to prevent any slight smears is as good as anything. I wouldn't risk any kind of polish on the metal surfaces as they are anodised and impossible to regain the high finish if you mess them up.
    Chris.
  • 10-16-2008 10:22 AM In reply to
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    I concur!!
    It's amazing what baby wipes will shift in the way of marks and stains without any damage to the surface - even stacking marks on the tops of the Beosystem components (albeit with a fair amount of elbow grease...)
    Cheers
    Nigel
