Hello everyone,
I'm wondering what I should use to clean the shiny surfaces of my Beosystem 6500. Also, is there any kind of polish I can use on the metal that won't cause damage to the finish?
Thanks in advance,
Aaron
Hi Aaron,
baby wipes followed immediately with a soft cloth to prevent any slight smears is as good as anything. I wouldn't risk any kind of polish on the metal surfaces as they are anodised and impossible to regain the high finish if you mess them up.
Chris.
I concur!!
It's amazing what baby wipes will shift in the way of marks and stains without any damage to the surface - even stacking marks on the tops of the Beosystem components (albeit with a fair amount of elbow grease...)
Cheers
Nigel
