Just so that you know, PL cables are generally available in 5meter, 10meter and 20meter lengths...by the time you buy the barrel connector and another set of shorter cables, the longer cables may well be cheaper. Contact your closest B&O shop and explore your options.
Unless you're dealing with cables already installed inside your walls or something...in which case, never mind.
Russ
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
