Ok, probably a silly question from a non-techy........... ;-) as I have moved some of my B&O bits around.
One of my set-ups is an Avant with an Overture via the MCL.
Pentalab 1's using the convertor cables (2 into 1 Y cable on each Penta) that then plug into the Avants Dolby sockets.
I was using Type 1 round cables and 'upgraded' to Type 3 Data round cables but all I get on the Penta LCD's is just CD showing and not anything else!?!?!?!? As an aside I think one of the LCD's has broken as it doesn't show anything any more. :-(
Is it because they is (as per Ali G, ho hum) Penta 1's that I don't get the display showing the correct input or is something just not configured correctly?
Cheers in advance.
GUY
Train Hard - Run Fast - Hit to Kill!!!
