Hello,
I have a Beosystem 7000 with 2 link rooms (MCL).
This morning I found out, the hard way, that the timer function in my link rooms didn't work anymore.
I can turn on and off the link room but I can't control the BM7000 (adjust volume, change source).
The mute control light doesn't light anymore, it only flashes when I use the remote.
Everything works correct in the main room.
My guess is that the datalink cable is disconnected somewhere.
But before I head up to the attic I would like to see if there can be anything else?
regards
Mikael
