Latest post 03-05-2009 12:19 PM by kimhav. 21 replies.
Page 1 of 1 (22 items)
  • 02-05-2009 4:35 AM
    • kimhav
    • Top 500 Contributor
    • Joined on 09-03-2007
    • Sweden
    • Posts 127
    BeoMaster 5 Hardware specs
    While it's hard to figure out what B&O has added inside the box - a good guess is that they're using the VIA EPIA EX-Series Mini-ITX board this time. For BeoMedia 1 they used also a VIA EPIA M II-series board (thread).
    Taken from the BeoMaster 5 manual we can see that the unit has the following connectivity:
    BeoMaster 5
    The VIA EPIA EX connectivity:
    VIA EPIA EX-motherboard
    and finally a little picture of the board itself:
    Guess that we have to wait for some one opening the unit to take a series of inside out pictures of the extra connectivity board.
  • 02-05-2009 5:00 AM In reply to
    Re: BeoMaster 5 Hardware specs
    kimhav:
    Didn't Keith do that months ago? Of course I can't find the thread now, but I'm pretty sure it wasn't a VIA board...
    -mika
  • 02-05-2009 5:27 AM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Well, I found the thread and as well Keith has set up an external site with some few pictures and from that I can only say that the Amitech is a Via Tech board or an OEM-version of Via Tech.
    Here is one shoot from his site showing parts of the motherboard:
  • 02-05-2009 10:27 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    hhm, as the Via motherboard is standard computer hardware it seems to be a wise idea to buy the same motherboard and archive it somewhere in your house - just in case ;-)
    As it is a embedded windows system and the board has an IDE-connector I imaginge a very nice idea:
    What about adding a CD-Rom to the system and put it in a DVD2-case? This would be a very nice base unit :-)
  • 02-05-2009 10:40 AM In reply to
    TWG:
    Great idea... even better: a DVD player/burner or a Blue Ray player, and that would replace the HDR 2 and DVD 2.
    p.
  • 02-05-2009 1:26 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Ok.we understand each otherBig Smile
  • 02-05-2009 1:42 PM In reply to
    • kimhav
    • Sweden
    • Posts 127
    TWG:
    The VIA EPIA boards are great boards; while would say that some of the boards could offer better audio chip than the VIA Vinyl used. Even though that it's far better than much other crap integrated on many boards. The board are well built and I've had couple of boards in several system. Also here in Sweden the boards are sold with either 3 or 5 years warrant.
  • 02-06-2009 5:59 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The audio chips in the motherboard aren't used, B&O uses their own...
     Weekly top artists:
  • 02-06-2009 8:26 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Alex:
    The converter is an Analog Devices AD1852
  • 02-06-2009 8:51 AM In reply to
    • Alex
    • Posts 2,990
    Exactly, not one built into the motherboard.
    On top of this, there are very few companies actually manufacturing microchips, I expect you'd find a surprising number of high-end companies all share very very similar components. For example, Naim have been known to use Burr-Brown converts, but what really makes the difference is how it's implemented.
     Weekly top artists:
  • 02-06-2009 9:30 AM In reply to
    AD1852 is a great chip, available from Analog Devices at the astonishing price of USD 8.10 if you buy more than 100.
    http://www.analog.com/en/digital-to-analog-converters/audio-da-converters/AD1852/products/product.html
  • 02-06-2009 10:05 AM In reply to
    • Puncher
    • Posts 9,588
    Exactly - it is a good quality, inexpensive part, available to all. Since B&O no longer publish circuit schematics we will never know if their particular inplementation varies in any significant way from the manufacturers published reference designs.
  • 02-06-2009 10:31 AM In reply to
    • Alex
    • Posts 2,990
    Just found this.
    From what it seems, the AD1852 seems to be quite difficult to implement correctly, but when it's done correctly it's a very high performance chip.
    Don't you do stuff like this Punch?
     Weekly top artists:
  • 02-06-2009 10:50 AM In reply to
    Not exactly cutting edge!! The conversation you point to occurred in 2002! Laughing
  • 02-06-2009 11:01 AM In reply to
    • Alex
    • Posts 2,990
    True, but I don't believe DACs have really moved forwards since then. After all, the DAC in the CD5500 & Co is 20 years old now and still highly regarded.
     Weekly top artists:
  • 02-06-2009 1:48 PM In reply to
    • Puncher
    • Posts 9,588
    Alex:
    Just found this.
    More a power man myselfBig Smile - I think the difference is if you're working on a "real" product then you speak directly to the manufacturers rather than enthusiasts forums for implementation advice (there will generally be less fairy dust in the reply too)Wink
  • 02-06-2009 3:11 PM In reply to
    • Alex
    • Posts 2,990
    Laughing Very scathing! Stick out tongue
     Weekly top artists:
  • 02-07-2009 5:04 AM In reply to
    • Puncher
    • Posts 9,588
    Alex:
    I wasn't trying to "dis" anyone, I'm sure there are some very knowledgable folk at loose on the hifi forums, alas there are also a lot whose enthusiasm outstrips theirs. You will have read enough stuff about cables, jitter and pyramids/crystals etc to know this is true. The trouble is trying to filter out the "noise" to reach the real factual stuff. Just imagine all of the pseudo-science written about cables and then scale that up to the realms of DAC performance/implementation and the extra scope this brings to baffle the innocent. It's also not unkown for enthusiasts to go to the ends of the earth to solve problems that aren't audible (although they will disagree).
    When I said "real" product, imagine B&O approaching Analog Devices and telling them they're using the AD1852 in a new product - the AD engineers will be happy to get involved and offer suggestions and help in achieveing the end result, after all the BM5 is from a manufacturer with a worldwide reputation. The "reputation" of Analog Devices' component itself is likely to be discussed when the product is released (and, funnily enough, here we are). We know the data sheets are available to all on the Analog Devices website but I would personally be amazed if they weren't able to give extra snippets of application advice above and beyond what is pulished on the website.
    I hope that's not too scathingWinkBig Smile
  • 02-08-2009 6:44 AM In reply to
    • Alex
    • Posts 2,990
    Fair enough - I have never really played with electronics like you have so bow to your knowledge of the chip.
    As for sound performance of the BeoSound 5 - bar the occasional song B&O supplies with the dealer versions which I know, I don't really have anything I can judge it's quality by. I'm in the process of setting up a media server in Bath which is going to provide us with a source of Lossless audio for our BeoSound 5 which is now running the final software. I'll do some listening when I've got all the music on the BeoSound 5, but from what I can tell by the songs which are available already, it's quite a smooth but detailed sounder. Does a very good job of highlighting the difference between a 128kbps and 256 kbps radio station...
     Weekly top artists:
  • 03-05-2009 11:55 AM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Alex:
    Just found this.
    Thanks for the link; speaking about DACs since I'm using a VIA Tech board in my BeoPort solution I got my self a Audigy 2 ZS Notebook card to see how big difference there is and.... Wow! Talk about more rich sound when using the Audigy 2 ZS board. I actually though there would be a difference, but that big. The normal Audigy 2 PCI board uses Cirrus Logic CS4382 and where it seems the notebook version make use of the Cirrus Logic CS4398 DAC instead.
    Cirrus Logic DACs
  • 03-05-2009 12:01 PM In reply to
    kimhav:
    I would expect this to be not so much a function of the actual DAC used, but what happens after it. Many digital designers - like those that would be responsible for most of your notebook motherboard design - are awfully ignorant of the good old analogue electronics and a single wrong choice in components or PCB routing can destroy the end result. Not to mention that a separate sound card is designed and built just for that, without many of the constraints of an integrated solution.
    -mika
  • 03-05-2009 12:19 PM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Agree; googling the net several also agrees that the notebook version of the Audigy2 card superior in audio quality. I was just lucky that I could make use of a pc-card since the dedicated BeoPort pc is a tiny box which is half the size bigger than a Mac Mini and PCI-card solution would work out.
    VIA EPIA M-II system
