Latest post 12-12-2007 8:19 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 12-12-2007 5:46 AM
    Beogram 5005 compatability
    I was recently given a Boegram 5005 as a gift and I am having a small dilemma.  I do not have a tuner/receiver that has a "phono" input. Should I buy a "phono pre-amp" to plug into my receivers'  'AUX' inputs, or should I go out and purchase a receiver that has an existing phono input?
    I'm sure this is common sense to most, but I am unsure and would prefer not to damage anything.
    Any help would be greatly appreciated.
    Josh
  • 12-12-2007 8:19 AM In reply to
    Re: Beogram 5005 compatability
    You won't do any damage Josh so don't panic!
    Cheapest option is a phono pre -amp and there are some available if you do an internet search. They range from £20 or so to prices that would require a second mortgage. I suggest £40 would buy you an adequate device including a din - rca converter which you will probably need.
    Regards Graham
