Latest post 12-10-2007 7:46 AM by beologisch. 1 replies.
Page 1 of 1 (2 items)
  • 12-10-2007 7:29 AM
    • JY
    • Not Ranked
    • Joined on 11-02-2007
    • Posts 6
    DVD1
    I am having trouble connecting my DVD1 to BV5.  The dvds play fine when connected using S-video cable but the screen flutters when the two are connected using a 21 pin cable.  I bought this cable at a local hardware store because I was reluctant to buy it from the local B&O dealer who asked for US 80 dollars.  Could this be the problem?  Are B&O 21 pin cables specially designed for B&O products?  Or is there another reason for this?
  • 12-10-2007 7:46 AM In reply to
    Re: DVD1
    I've had the same problem a few years back; the first scart/21 pin cable did not do anything at all, the second one I tried gave a shivering image on my avant and the third one did the job, the difference was the price.......:-) because the cheapies were not completely 21 pin wired.
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
