1st March February 2012
Latest post 11-22-2007 1:59 AM by Toubro. 12 replies.
Toubro
- Joined on 04-16-2007
- Copenhagen, Denmark
- Posts 263
Sounds strange, now the picture and link works here, and it should be viewable for everyone. If it still won't work, I'll try and explain. The display is just blank and backlit, and when the ringing tone sounds all the of the displaydots turn black, and then turns back to being blank and backlit, it looks really strange. Thanks for your help.
SWISS_2
- Neuchatel, Suisse
- Posts 552
I've seen this once with my Beocom 6000 with our electricity ( 230V ) going out. You might take the battery out of the phone for 10-20 minutes and then reset it inside again. Your previous stored data will have been lost inside, which hopefully you can reinstall. Interestingly enough, our gold Beocom 2 had sustained no data loss problem: Only the Becom 6000. As a result of this experience in 2004, both phones are now on surge protectors, including the phone lines. Both units purchased a in 2003 from the store in Frankfurt Am Main. Do you recall if the power mains in your house came back up slowly, or all at once ?
Santiago
- Switzerland
- Posts 3,286
Toubro:Sounds strange, now the picture and link works here, and it should be viewable for everyone.
"ForbiddenYou don't have permission to access /e107_plugins/autogallery/Gallery/DSCN2505.JPG
on this server"
Toubro
- Posts 263
Santiago:"ForbiddenYou don't have permission to access /e107_plugins/autogallery/Gallery/DSCN2505.JPGon this server"
Stupid website, it should be possible, oh well, maybe this works, but I won't guarantee it :o) http://toubro.dk/e107_plugins/autogallery/autogallery.php?show=DSCN2505.JPG
The display works fine, except on incoming calls, that's what's so weird. Everything is fine, the menu, phonebook you name it. I've tried disconnecting the battery one of the phones, (as I only thought it was that phone to begin with), but that didn't change anything, but it was only unplugged for half a minute or so, so I'll try and disconnect it for longer. The base has also been disconnected without success, but only for a minute. Thanks for your suggestions.
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
This is a really strange problem statement with your two Beocom 6000's Firstly, whilst a "brown out" or power failure could cause problems with the base, I fail to see how such failure would effect two Beocom 6000 handsets in exactly the same way. Also if the Base was at fault, it still has no way of effecting the display in the manner you have described. In fact if you had no base at all the display would still function. I am assuming that both Beocom 6000 handsets have exactly the same problem. Please confirm ? Which version of Beocom 6000's do you have ? Mark I has a DOT to the left of the dial and Mark II has INT Brownout Definition: A reduction in the mains voltage without a complete loss of power. A brownout is a steady lower voltage state. An example of a brownout happens during peak electrical demands in the summer, when utilities can't always meet the requirements and must lower the voltage to limit maximum power. When this happens, computer systems can experience data corruption, data loss and premature hardware failure and Video and audio systems can have variable symptoms including speaker noise, shutdown/restart and switch off.
Toubro
- Posts 263
Keith Saunders:Well, you have brought a new variable into your problem statement "Caller ID" Now we fully understand the situation, I can confirm that on Mark I Beocom 6000's they will briefly flash the blank display if you do not have the caller ID service enabled.
Haha, I thought something was wrong and made a big thing out of it, and then it turns out it is just because of the lack of caller-ID. Thank you very much for your help, I'll try to ask if my father has changed anything the next time they have a beo problem :o)
Page 1 of 1 (13 items)
