Latest post 01-18-2008 6:40 PM by mAtHiAs. 68 replies.
Page 1 of 3 (69 items) 1 2 3 Next >
  • 11-20-2007 10:55 AM
    Hard to choose between Beolab 8000 or Beolab 3
    Hellu B&O people
    First of all - thanks for this site, its really handy Yes -  thumbs up
    Now to the problem; How to choose between the BL 8000 & the BL 3?
    I mean,, the design aswell the sound in the BL 8000 is magic,, but i fear
    the day when we are parents! I wont let our child play near the speakers
    & the problem is that U cant be around them all the time!
    The BL 3's are also fantastic (though the design isnt as magic like the BL 8000's)
    but the advantage is that they can be placed on the wall  =)
    So,, the question is - DO WE MISS ANYTHING IF WE CHOOSE TO GO WITH THE BL 3'S in the soundIdea
    I almost forgot,, we will use a Beocenter 9500 with the speakers!
    Best regards
    Mathias, Sweden
  • 11-20-2007 11:31 AM In reply to
    Re: Hard to choose between Beolab 8000 or Beolab 3
    I have Pentas and have had no problems with either children or dogs as far as they are concerned. It takes quite a bit to knock over an 8000 so if you prefer them, get the 8000s. The 3s are excellent speakers but will not produce quite the same sound pressure in a larger room. It does depend on how loud you like your music! Of course Pentas are another option!
  • 11-20-2007 11:43 AM In reply to
    Hi Peter,
    I bow to your greater experience when it comes to loudspeakers, but I thought that the BL3's would produce more sound than the 8000's?
    Don't they have much larger ICEpower amps (250W each) compared with the analogue 8000's?
    I think the 8000 vs 3 debate will always be personal opinion - but if I was taking one pair of speakers out to make the most 'noise' it would be my 3's, as the 8000's always sound a little 'fragile' when cranked up loud?
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
  • 11-20-2007 11:48 AM In reply to
    Thank u for your fast reply Peter!
    I know that the Penta are a really good speaker, but
    i have allways been in love with the BL 8000's!
    It's interesting that u say that the sound pressure is better
    in the BL 8000's,, i understand that the midrange is
    more powerful in the BL 8000's!
    But how about the overall sound,, even at low volumes????
  • 11-20-2007 12:34 PM In reply to
    At work so I don't remember completely but the sound pressure generated by 8000s is about 99dBa , Pentas 101dBa, and BL3s were about 95dBa. This is a big difference but to be honest, no-one really uses this sort of level. Most sound pressure is at the lower end of the frequency scale - the BL2 can produce more than the Pentas - and this is why you need to take power outputs with a pinch of salt. Yes the BL3 has two ICE amplifiers rated at 125W, but one is going through the small tweeter and will probably not produce much more than 1W . B&O stopped producing sound pressure levels when the BL3 came out!! Laughing
  • 11-20-2007 1:59 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Have a listen to them. I've found that the BeoLab 3s tend to go deeper than the 8000s, and produce more bass, and are also generally faster and more detailed - better for electronic/rock music!
    However if classical music or jazz is your thing, you'll probably prefer the 8000s, they're 'smoother', but IMO an 'older' sound, don't touch the 3s when it comes to detail, and powerful snappy basslines (the BeoLab 3s can be really quite fantastic for this, even in the lower-end of large rooms). For large rooms though, BeoLab 8000s will generally be better as they don't tend to 'scream' at higher volumes, whilst the BeoLab 3s can start to sound pretty 'strained' at higher volumes.
    With a subwoofer though, I'd always prefer the 3s, but all above is mostly personal preference which is the most important thing when choosing speakers. Have a listen to the speakers yourself, and if your dealer will let you (most will), try the speakers out at home with the kind of music you listen to, at the kind of volumes you prefer.
     Weekly top artists:
  • 11-20-2007 2:49 PM In reply to
    I cant stop my kids touching the gloss black kitchen units which leave hand prints all over, but they know the B&O speakers, sterio and TV is a definate NO NO as far as touching or messing with. They have learnt this from day one, so im sure you can teach any future children the same principles. Get the 8000's.
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
  • 11-20-2007 3:14 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hear, hear! (Here,here)(we never did sort that one out)
    Both my grand children, one nearly 5 years and the other 18 months, know not to touch my Pentas, Avant or 8000s.
    The trick to training them, is down to the method you use to rock them to sleep..............................
    ....................Use a bigger rock!LaughingLaughing
    Andy T.
    Poor me, never win owt!
  • 11-20-2007 4:53 PM In reply to
    I start by saying - Thank you all for your reply's...
     We're stuck,, it's not a "light" choise to make,,
    we're concerned about the sound & looks,,
    we care about the placement,, but it's wrong
    to let the placement choose..........
    Aghhhhhhhhhhhhhh,, we are really stuck Unsure
  • 11-20-2007 5:03 PM In reply to
    Beolab 9s? Squatter but better sound and probably more child friendly.
  • 11-20-2007 5:07 PM In reply to
    Peter:
    "Daddy? Can the penguins sleep in my room tonight?"
  • 11-20-2007 5:12 PM In reply to
    soundproof:
    Peter:
    LaughingLaughingLaughing Choosing between the BL 8000's and BL 3's is hard. Personally I would favour BL 8000's, but I think Peter has a good point with the BL 9's. They are better than the 8000's and 3's.
  • 11-20-2007 5:15 PM In reply to
    • Alex
    • Posts 2,990
    I agree with Peter about the BeoLab 9s. Superior to the 3s and 9s in every way, and much more stable...
     Weekly top artists:
  • 11-20-2007 6:11 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    mAtHiAs:
    i have allways been in love with the BL 8000's!...
    If you have decided for the BL8000, but only fear they could fall (which is very unlikely to happen) you should get them. Otherwise you will always regret not to have bought them. And they are fantastic speakers.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 11-20-2007 9:21 PM In reply to
    Dear All:
    There is a bracket that will allow you to wall mount the BL 8000s.  The cool thing about the wall bracket is that you'll just see the tip touching the floor.  The visual effect is fantastique.
    Dario
    When I hear music, I fear no danger. I see no foe... Thoreau
  • 11-21-2007 1:55 AM In reply to
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Dario, do you now where i can buy the wall mount for BL 8000s ?
    Regards
    BL8000 MkII Black
  • 11-21-2007 6:50 AM In reply to
    I know about the wall/celling bracket,, but i think that i takes away to much of the magic in the BL 8000's.
    Offcourse we have  the alternatives,, the BL 9's,, but the price range is a little bit to high & in my eye's
    the BL 9's arent as magic in the design as the BL 8000's... Or are they Hmm
  • 11-21-2007 7:11 AM In reply to
    I don't think it helps the performance much to have the BL8000s attached to a wall ...
  • 11-21-2007 7:26 AM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    soundproof:
    could be true, soundproof.
    But I have never heard of or seen a bracket for BL8000. I know there is one for the BL6000, but for the BL8000. Are you sure about this?
  • 11-21-2007 7:31 AM In reply to
    tom:
    soundproof:
    As you, I only know of the one for BL6000. But there's a post above claiming there is one for BL8000. I'd use the BL6000 one if I used those for surround, but not as front speakers, as I think they sound better (6000 and 8000) when they're free from the wall.
  • 11-21-2007 7:36 AM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    I have seen pictures (on the old forum I believe) of 8000's ceiling mounted (upside down)!
    They were certainly striking although I'm not sure I would do it myselfErm
  • 11-21-2007 7:55 AM In reply to
    Puncher, I believe this is what you mean. Another one here
  • 11-21-2007 8:02 AM In reply to
    • Puncher
    • Posts 9,588
    Yup - not sure they are the same pictures (or even the same installation) but that was the idea.
     Having seen them again though they seem plainer than I remember - definitely wouldn't do it myself!
  • 11-21-2007 8:58 AM In reply to
    See this link for a pic of the BL 8000's mounted in the celling,, no magic like i said!
    www.bang-olufsen.com/beocustom/home.asp?sorted=1&projID=67&book=1&typeID=&projCont=&country=&locID=&strCont=&country2=
  • 11-21-2007 10:23 AM In reply to
    • Puncher
    • Posts 9,588
    They look peculiar without the base block. I thought the ceiling mount picture I had seen still included the base blocks (although I could have dreamt it).
