When came BeoSound 9000 mark III? And was there red main switch button in Mark II or only in Mark I ? I'm asking this, because I'm not sure if I have Mark II or III. I bought Mine somewhere between 2000 and 2002 but not sure when
You can check the type number on your BS9000
MKI: 2521-2531
MKII: 2561-2570
MKIII: 2571-2580
Hope that helped you
fleeters:Hi,You can check the type number on your BS9000MKI: 2521-2531MKII: 2561-2570MKIII: 2571-2580 Hope that helped you
Great, thanks alot!
