Latest post 11-14-2007 4:34 AM by ProGram. 4 replies.
Page 1 of 1 (5 items)
  • 11-14-2007 2:11 AM
    BC9500 outboard equalizer
    Hi...I'm wanting to run an equalizer (passive ie, tape in / out) with my BC 9500....How do I do it...???
    What adapter plugs do I need with a RCA input and RCA output Passive EQ only..(Pioneer SG-9500).....
    Thanks,
    K
  • 11-14-2007 3:02 AM In reply to
    • ProGram
    • Top 500 Contributor
    • Joined on 06-01-2007
    • NRW, Germany
    • Posts 145
    Re: BC9500 outboard equalizer
    Hi!Your BC 9500 has a special line-in-out socket, wich is covered with a shortcircuit-cap (when not used), Only pull that off and plug in a DIN-RCA-adapter and you have the in's and out's ! (DIN pin 1 is out right, 4 is out left, 3 is in right and 5 in left). Cheers Chris Btw: this signal is volume contolled!
  • 11-14-2007 4:00 AM In reply to
    Unless I have misread the circuit diagram, this output is NOT volume controlled. Perhaps Keith will check.
    Regards Graham
  • 11-14-2007 4:04 AM In reply to
    So I need a DIN with 2 ins and 2 outs...and then just hook up like an "adaptor" ??? Do I need to make any remote changes or will this equalize the whole signal before the internal amp and the powerlink outs??
  • 11-14-2007 4:34 AM In reply to
    • ProGram
    • NRW, Germany
    • Posts 145
    Hi!You are right, my fault. It's located between inputcontrol and tone/volumecontrol, sorry. Hadn't put my glasses on.
