Latest post 11-05-2007 11:50 AM by mhh. 6 replies.
Page 1 of 1 (7 items)
  • 11-05-2007 3:40 AM
    • mhh
    • Not Ranked
    • Joined on 11-05-2007
    • Adelaide
    • Posts 6
    BV 7 says "WAIT"
    My BV 7 shows "wait" in the top right corner (where the clock normally shows) and has a blank screen and won't respond to any commands from the remote.  Has it died?  Can anyone suggest a fix?
     TIA
    Mark
  • 11-05-2007 3:46 AM In reply to
    • David
    • Top 500 Contributor
    • Joined on 05-05-2007
    • England
    • Posts 128
    Re: BV 7 says "WAIT"
    Have you tried unplugging and re entering the pin code?
    Beolab 8000, Beolab 6000, Beolab 2, LG CX65, Beosystem 3, Beosound 9000, Beolab 3500
  • 11-05-2007 3:47 AM In reply to
    • mhh
    • Not Ranked
    • Adelaide
    • Posts 6
    I've tried unplugging but all I get when I turn it back on is WAIT.  Shouldn't it prompt for the PIN?
    Edit:  The screen is dead.
  • 11-05-2007 4:01 AM In reply to
    Has the PIN been entered wrong? This could be the reason....
  • 11-05-2007 4:47 AM In reply to
    • mhh
    • Not Ranked
    • Adelaide
    • Posts 6
    marcus_m:
     Not by me, but the kids may have tried to enter the PIN after the unit was switched off.  I guess I need to get a B&O tech to help.
  • 11-05-2007 5:06 AM In reply to
    Leave it in standby for 3 hours, the pin protection circuit will then be reset and will allow you to re-enter it.
  • 11-05-2007 11:50 AM In reply to
    • mhh
    • Not Ranked
    • Adelaide
    • Posts 6
    Many thanks - waiting fixed it as you said it would. Smile
