Latest post 10-31-2007 5:57 PM by ahoover. 0 replies.
Page 1 of 1 (1 items)
  • 10-31-2007 5:57 PM
    Setting up Beosystem 1, Beovision 4-50 System with S-A Explorer 8300HDC - Guidance Requested
    Hi:
    I'm setting up Beosystem 1, Beovision 4-50, DVD-1, Beosound 9000, Beolab 1, Beolab 2, BeoLab 6000, Beolab 7-2 with a Scientific Atlanta Explorer 8300HDC set-top HD digital video recorder. I would like specific detailed advise on cabling these devices together.
    I am thinking the DVD-1 should be connected as follows:
    DVD-1 <to> DVD Input System1
    Digital Output - RCA Phono <to> COAX - RCA Phono Orange
    Audio Left <to> LEFT - RCA Phono White Back
    Audio Right <to> RIGHT - RCA Phono Red Back
    Data Mini Jack <to> CTRL Mini Jack Back
    YC -AV S-Video Cable <to> S-VIDEO Back
    CVBS <to> VIDEO - RCA Phono Yellow Back
    I am thinking the Scientific Atlanta Explorer 8300HDC should be connected as follows:
    Scientific-Atlanta Explorer 8300HDC Rev6.3 to STB Input System1
    Video Out RCA Phono Yellow - Out 2 <to> Video - RCA Phono Yellow Back
    Digital Audio Out RCA Phono Black Out 1 <to> COAX - RCA Phono Orange Back
    CRTL - Mini Jack Back <to> CRTL - Mini Jack Back
    Left - RCA Phono White Phono Audio Out 1 <to> LEFT - RCA Phono White Back
    Right RCA Phono Red Phono Audio Out 1 <to> RIGHT - RCA Phono Red Back
    Video Y/V - RCA Phono Green - Out 1 <to> Y/G - RCA Phono Green Top Panel System1
    Pr - RCA Phono Red - Out 1 <to> Pr/R - RCA Phono Red Top Panel System1
    Pb - RCA Phono Blue - Out 1 <to> Pb/B - RCA Phono Blue Top Panel System1
    Beovision 4-50 Plasma Control Cable DB9 <to> USB2 to DATA System1 USB2 Jack Back
    BeoSystem 9000 Beo Master Link RG Connector <to> System1 Masterlink Top Panel
    BeoSystem 9000 DIN <to> Apple Airport Audio Out Mini Jack
    Beo Eye <to> System1 IR Receiver Mini Jack Top Panel System1
    RGB 5 BNC Connector Cable <to> System1 PROJ OUT DB15 Top Panel
    Are the connects correct and are there any special configuration settings/configurations/software-code releases for the Beosystem 1 or Beo 4 remote? Does the S-A Explorer 8300HDC require any specific set-up/config ie 1040i only?
    Thank you in advance,
    Al
    Filed under:
