Latest post 04-23-2007 11:25 AM by Beonut. 4 replies.
Page 1 of 1 (5 items)
  • 04-21-2007 11:21 AM
    • Corvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Australia
    • Posts 124
    Beosystem 3 with External STB
    When changing channel on my external set top box, the centre speakers (BL4000's) switch off and on each change. It is annoying as these speakers have a reasonable loud relay in each.
     Any suggerstions on a fix for this?
  • 04-21-2007 7:16 PM In reply to
    • Corvin
    • Australia
    • Posts 124
    Re: Beosystem 3 with External STB
    Anyone have any clues?
  • 04-23-2007 5:06 AM In reply to
    • Beonut
    • Joined on 04-17-2007
    • Essex, UK
    • Posts 89
    Hello Corvin
    I see a similar symptom with some channels on my UK Sky HD stb, it seems to be channel related, on a few channels the BS3 continually switches from speaker 3 to speaker 5. Im guessing this is broadcast related as it is only a small number of channels where this occurs.
    Cheers
    Peter
    My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
  • 04-23-2007 8:43 AM In reply to
    • Corvin
    • Australia
    • Posts 124
    Beonut,
     Thanks for your input. I am using a free to air HD STB and it occurs every change and unrelated to the sound encoding. I am guessing that the BS3 is losing signal and re-gaining may cause it to switch. The biggest disturbance is the loud relay's in the BL4000's. Hope i can find a solution.
    Thanks,
  • 04-23-2007 11:25 AM In reply to
    • Beonut
    • Essex, UK
    • Posts 89
    Corvin
    Just a suggestion perhaps a post about the speakers in question rather than the bs3 regarding quietening the relays may get a response.
    Cheers
    Peter
