Latest post 10-30-2007 3:56 AM by GuyHui . 5 replies.
Page 1 of 1 (6 items)
  • 10-28-2007 10:06 AM
    Import iTunes library
    Hello,
    I need some advice from you all :
    I saved my former iTunes library form my PC and brought back to my new iMac using the FTP protocol.
    When loading iTunes, I can't find my fomer configuration as before.
    Here is how i managed my folder :
        Musique/Itunes (folders configured like this in the firm)
                             I_Itunes Library
                             I_Itunes Music
                             I_Itunes Music Library.xml
                             I_Previous Itunes Library
                             I_ITunes Artwork
    Did I miss something?
    BTW, I am not realling willing to build again a new configuration on Itunes (hours of copying CD.....)
    Thanks for your help.
    Guy
    --= "Everything gets done with Patience" =-- --= "Less is More" - Mies Van der Rohe"
    --= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
  • 10-28-2007 10:20 AM In reply to
    Re: Import iTunes library
    Did you just save it onto another HDD? I just drag and drop the iTunes music folder into the Library folder of iTunes and it seem to just do it! Done from mac to PC and vice versa.
  • 10-28-2007 10:52 AM In reply to
    Thnaks Peter,
    In fact I just saved it in my current Mac HDD. It does no run...
    Where I saved is in the folder Music/Itunes. By the way, I can see a Libray Folder of Itunes.
    I have in my Itunes folder the :
    - Album network (folder)
    - Itunes library (data file)
    - Itunes Music folder
    - Itunes Music library.xml
    I also tried to drag and drop in the folder Bibliothèque/Itunes where there is the Itunes Plug-ins folder.
    It does no run...
    The folder Bibliothèque is the one where there is all the programs installed, like the program files folder on windows.
    Cheers Peter,
    Guy
  • 10-28-2007 5:46 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Hold down the ALT key whilst opening iTunes (some of your open programs may disappear, just click their icon again to get them back). A window will appear asking you to either 'cancel', 'create new library' or 'choose library'. Click 'choose' and select the file I_Itunes library. Finder should highlight as the only 'acceptable' file in the folder.
     Weekly top artists:
  • 10-28-2007 7:21 PM In reply to
    I will give a try tomorrow and will let you know;
    Good evening;
    Guy
  • 10-30-2007 3:56 AM In reply to
    Finally, I did it. Thank you all for you help.
    Guy
