Latest post 10-26-2007 2:01 AM by marcus_m. 2 replies.
Page 1 of 1 (3 items)
  • 10-25-2007 5:49 AM
    • GSHaigh
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North West UK
    • Posts 163
    Beo5 Config Software with BeoPlayer / BeoPort
    I have just upgraded my BeoPort software, which included an un-install.  After this process I had to re-install the Config software.  Just a warning.
    Greg
  • 10-25-2007 3:49 PM In reply to
    Re: Beo5 Config Software with BeoPlayer / BeoPort
    Why did you have to uninstall the previous version of Beoport ? It should just update the installed version unless you have a corrupt installed version.
    Regards Keith....
  • 10-26-2007 2:01 AM In reply to
    Tried to upgrade BeoPort yesterday from 4.50 to 4.65, but it did not work either. So I also had to uninstall the previous version.
    Can't comment on the problem with the Beo5 SW, as it is on a different pc.
    Marcus
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
