Latest post 10-08-2011 6:32 AM by root. 6 replies.
Page 1 of 1 (7 items)
  • 10-22-2007 9:12 AM
    Avant Contrast Screen
    Is it possible to remove the contrast screen on a curved screen Avant? Mine's a bit grubby and I would like to give it a clean. Is it just brute force on the plastic sorround and I am being too careful.
  • 10-22-2007 11:55 AM In reply to
    • saf
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 458
    Re: Avant Contrast Screen
    Don't use brute force removing the plastic surround: there are two (large plastic) screws standing in your way. You will find them if you look below/under the screen and surround, just where the red on/off switch is hidden...
  • 10-22-2007 4:30 PM In reply to
    is it a 28" or 32" ?
  • 10-26-2007 3:16 PM In reply to
    Its a 28".
    Basically I presume you can remove the black plastic trim from around the screen. I have so far been unable to do this. Is it possible and does the glass screen come off after that.
  • 10-27-2007 6:31 AM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    The screws are internal, unlike the LX and MX series. You have to take the back off the Avant to access them - and this should only be undertaken by a qualified technician.
  • 10-27-2007 11:24 AM In reply to
    Cozza is correct. The later RF models are easy but the curved ones need to have the rear panel off and I cannot recommend this unless you know your way around a TV set. Very dangerous!! I certainly would not do it.
  • 10-08-2011 6:32 AM In reply to
    • root
    • Joined on 04-16-2007
    • Posts 163
    • Silver Member
    Sorry to bring this old thread up again..
    I have a curved screen 28" vcr model here and it has spent its life in the living room of a heavy smoker. So it's in desperate need of a good clean of the glass screen in front of the tube.
    There is no service manual on site and I'm not a fan of trial and error:)
    Could somebody let me know please how to remove that plastic trim?
    Marcel
