Latest post 10-16-2007 8:15 AM by ®. 7 replies.
Page 1 of 1 (8 items)
  • 10-15-2007 10:56 AM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Beovision 7-32 & Beolab 7.4
    Does the Beolab 7.4 fit the Beovision 7-32 with floor stand easily or does it require modification?
    Does anybody have a 7-32 with 7.4?
    Any photos would be appreciated.
  • 10-15-2007 11:18 AM In reply to
    Re: Beovision 7-32 & Beolab 7.4
    Either BeoLab 7.1 or 7.4 fit onto the stand with their relevent mounting plate.
  • 10-15-2007 1:27 PM In reply to
    • beoben
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Germany
    • Posts 189
    Yes it does, I don´t have one but i´ve seen a red (!!!) 7-32 with a red 7-4 on floor stand at my dealer. Very nice
    I want a BV 10
  • 10-15-2007 4:35 PM In reply to
    • Roger
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    You will simply have to buy the bracket with item no 2184 (for single pipe stand, compared to the two pipe design of the 7-40). This will cost approx £40.
    Roger
  • 10-16-2007 4:55 AM In reply to
    britpop:
    Hi
    The lab 7-4 fits very well with a BV 7-32. I have this setup myself and actually think it looks better than on the 7-40.
    No problem fitting it and the sound in a surroundsetup is amazing...
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 10-16-2007 5:31 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Ehlerz:
    I have a photo but dont know how to add it. Seems i can only add from URL and not my local HD?
    Don´t use the icon with the tree (insert/edit image).
    Change to [Options] instead of [Compose]. You´ll find it higher up (under "Replying to an Existing Message). And click on "Add/Update"
  • 10-16-2007 6:11 AM In reply to
    Daniel:
    Ehlerz:
    Big Smile Thanks...
  • 10-16-2007 8:15 AM In reply to
    • UK
    • Posts 970
    and thank you for the photo.
