Keith,
Thanks for that very detailed response.
Years ago, when i was first getting into Hi-Fi, i first noticed it with my Pioneer Sx-580 Receiver and all that was needed was to unplug the unit from the wall and rotate the plug 180 degrees, and the problem/grounding went away. (And i should probably have titled the Thread as "Grounding Issue" rather than polarization (which is usually a problem with speakers when you accidentally connect the speaker wires backwards on only ONE speaker. (ie. right speaker - red to red, white to white & Left speaker red to white, white to red) Which in turn just kills any chance of 'sweet spot' center imaging (but you knew that).
But back to the issue - Strange. Last night when i went to bed, i turned off the BS4 but left the 4000's on like i usually do. This morning, got up and did the 'test' against the speakers and surprisingly felt NOTHING. I turned on the BS4 to see if that would affect anything and still no problem. Very Strange.
I am going to file this one under 'monitor'. And to answer your question, no, its not static buildup but a (was) constant light sensation feeling against the skin.
Thanks!
stevo
