Latest post 06-19-2008 3:32 PM by Jandyt. 17 replies.
Page 1 of 1 (18 items)
  • 10-13-2007 6:28 AM
    Product Configuration Guide
    I have just been sent the newest version of the Product Configuration Guide! Only having a Mac, I cannot use this but I have put it on site! Try here - remember once you download it to change the extension pdf to exe - I cannot put program files on the site so I have changed the exe to pdf to fool the system! You need to change it back and it will work! let me know if much has changed!!
  • 10-13-2007 7:33 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: Product Configuration Guide
    BeoVision 8, BeoVision 9, BeoSystem 3,
    first changes i noticed in the PCG.
  • 10-13-2007 7:54 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Just noticed that it shows BeoVision 8 in 26" with and without ML
    and in 32" with and without ML.
    I was under the impression that only the 26" had a version without ML.
  • 10-13-2007 8:02 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Sorry to sound really thick, but at what point do I change the file name to exe?
    Andy T.
    Poor me, never win owt!
  • 10-13-2007 8:12 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    jandyt:
    Andy T.
    After download, you locate the file on your harddisk.
    Right-click on the file, choose "rename" , then replace .pdf  with .exe.
    Your pc will give a warning (are you sure blah blah), accept et voila !
    The file has been renamed, after which you double-click to install the PCG,
    either choose install for a new installation, upgrade if you have previously installed PCG on your pc.
    Smile
  • 10-13-2007 9:34 AM In reply to
    Be aware that it sometimes can be a little flaky! I have had several goes in the past to get it to load - probably better with XP.
  • 10-13-2007 9:52 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Peter:
    No problem with XP.
    I'd like to install it on my MacBook Pro as well, can i use BootCamp or VMware Fusion or similar ?
  • 10-13-2007 10:06 AM In reply to
    No idea! Laughing Let us know!!
  • 10-13-2007 10:26 AM In reply to
    • PeterC
    • Not Ranked
    • Joined on 05-01-2007
    • Bristol
    • Posts 20
    VMWare Fusion should work, as should Bootcamp. I've had success with the former, running Windows XP Professional
  • 06-18-2008 6:11 PM In reply to
    • Jandyt
    • Posts 13,004
    Try as I may, I can't get the PCG sorted!!!!
    I have downloaded the newest Adobe Reader but when I download the PCG it does not have .pdf on the end of the file name, so how can I change it to .exe? Really frustrated now.
  • 06-18-2008 6:18 PM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Jandyt:
    Where are you downloading the PCG from??? If its from the original link in this thread then save the file to somewher you can find it (e.g. desktop) and then right-click the file and select rename. Then change the suffix from .pdf to .exe. Enter to save  the change and then double-click to run installation.
  • 06-18-2008 6:27 PM In reply to
    • mhw
    • Top 500 Contributor
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    Jandyt:
    If you don't see the file extensions, follow these steps:
    1. Open My Computer or Windows Explorer.
    2. On the Tools menu , click Folder Options.
    3. Click the View tab.
    4. Click to clear the Hide extensions for known file types check box.
     Then you will see that your files will get endings like .exe or .doc, and then you can easily change themSmile
  • 06-19-2008 2:16 AM In reply to
    Andy,
    You can download the PCG HERE without changing the file extension.
    Regards Keith....
  • 06-19-2008 7:20 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    FYI, if you are planning to use the Product Configuration Guide-software
    for configuration of setups which also include older B&O products, f.e. MX7000,
    my advice would be to use a previous version of the software,
    as the current version (May 2008) has several errors / bugs in it
    (if speakers are selected for MX, no audio-products can be selected),
    Next to this, the displayed "recommended setup" isn't always correct
    when it comes to connections (f.e. "connect DVD to AV1 on MX7000", which should be AV2.
    We (Keith and i) have tested the PCG-software on other pc's as well --> same error.
    Regards,
  • 06-19-2008 8:20 AM In reply to
    Sorry for this question. What is the product configuration guide? Something that just explains which Option to set components to ?
    Thanks!
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 06-19-2008 8:23 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    It shows the type of connections, which sockets, software-versions, Option-settings,
    limitations for specific products, tuning information, Link-room setup (4 rooms max.),
    setting of switches of Beolab, speaker-setup (surround), cable-types (Powerlink), and so on.
  • 06-19-2008 8:41 AM In reply to
    ...and it is a software not just a document, just in case it is not clear. You select all the products you have in each room and it tells you how to connect them, configure them and what are the limitations.
  • 06-19-2008 3:32 PM In reply to
    • Jandyt
    • Posts 13,004
    Thank you alll for your helpBig Smile
    PCG working now. Mostly due to mhw but I'm sure you would have all got me sorted.
    Andy T.
