Regarding the auto-standby-mode; if the LINE-IN-MODE switch is set to ON,
the Lab4 will remain switched on.
But you can connect the Lab4 and set the switch to AUTO when you connect them to your audio-system.(mini-jack-mono)
It may take a few minutes before the Lab4 will go into standby.
