Latest post 10-13-2007 2:04 PM by bosteve. 5 replies.
Page 1 of 1 (6 items)
  • 10-12-2007 3:10 PM
    • bosteve
    • Not Ranked
    • Joined on 09-16-2007
    • Wiltshire
    • Posts 8
    Avant to Ipod
    Hi
    Just about to buy a Avant TV 2000 model been told i can connect a ipod to this anyone know where from cost how its done etc
    Thx
    Steve
  • 10-12-2007 3:23 PM In reply to
    • Ian
    • Top 500 Contributor
    • Joined on 04-16-2007
    • UK
    • Posts 132
    Re: Avant to Ipod
    This is the cable you need:
     http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260095369072
    It plugs in behind the timer panel of the Avant (top right).
    If you email the seller he can make any length you need.
    Ian
  • 10-12-2007 3:25 PM In reply to
    • Joe
    • Not Ranked
    • Joined on 10-03-2007
    • SoCal
    • Posts 74
    Re: Avant to Ipod
    Buy a 6270541 and connect it to any of the inputs from the Avant e.g. VCR or V.Aux. Select "Generic" source in the menu and you are done. The cable is anywhere from $20-50US.
    Joe
    Its not just a product, its a way of life...
  • 10-13-2007 5:24 AM In reply to
    • bosteve
    • Not Ranked
    • Wiltshire
    • Posts 8
    Re: Avant to Ipod
    Thanks guys thats what i thought i needed.
    Any thoughts or do u have a ipod going through a B&O system my local dealer says it should sound excelent ?
    Steve
  • 10-13-2007 6:16 AM In reply to
    Re: Avant to Ipod
    It does! I find it best to use mine via the dock connector - the volume seems better. The quality obviously depends on the compression you have chosen to rip at.
  • 10-13-2007 2:04 PM In reply to
    • bosteve
    • Not Ranked
    • Wiltshire
    • Posts 8
    Re: Avant to Ipod
    Ok thx 4 that and to let anyone know or if ur interested im selling a ms6000 on motorised floor stand and beo4 with new pcb board 2 days ago in wiltshire £200ono
    steve
