Latest post 10-15-2007 7:10 PM by Santiago. 12 replies.
Page 1 of 1 (13 items)
  • 10-10-2007 6:36 PM
    • GSHaigh
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North West UK
    • Posts 163
    Software Version
    Hi
    Could anyone confirm that v1.0 is the latest / only version of the configuration software?
    Greg
  • 10-11-2007 9:46 AM In reply to
    Re: Software Version
    Greg,
    The latest Software Version is 1.20a
    Regards Keith....
  • 10-11-2007 9:50 AM In reply to
    • GSHaigh
    • North West UK
    • Posts 163
    Thanks Keith.   I have v1,  will I have problems configuring the Beo 5 with this version?
    Greg
  • 10-11-2007 9:58 AM In reply to
    Greg,
    You will not have problems and anyway when your dealer makes any configuration updates to your Beo5 it will also update the software if an update is available.
    Regards Keith....
  • 10-11-2007 10:24 AM In reply to
    • GSHaigh
    • North West UK
    • Posts 163
    So is v1.20a the firware version of the Beo5 rather than the Configuration Software version?
    Greg
  • 10-11-2007 10:52 AM In reply to
    Greg,
    Yes, this is the firmware version, in other words the actual software that runs on the Beo5 Freescale MC9328MXS processor which executes the download configuration file produced by your dealer.
    Regards Keith....
  • 10-11-2007 11:25 AM In reply to
    • GSHaigh
    • North West UK
    • Posts 163
    Unless you're going to program the Beo 5 yourself Wink
  • 10-11-2007 2:27 PM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    GSHaigh:
    I want to program it myself. Even with a fairly exhaustive list given to the dealer it still hasnt turned out as I would like it and is operating way below its capability
  • 10-13-2007 12:18 PM In reply to
    GSHaigh:
    Hi
    Greg
    Hi Greg,
    the configuration tool version downloaded this morning by my dealer directly from B&O servers is:
    BEO5ConfigTool Version: 1.00
    Serializer Version: 0.35
    Regards.
    Santiago
  • 10-15-2007 9:03 AM In reply to
    Keith Saunders:
    Greg,
    The "Product information" screen of my beo5 say: Software version: 1.12a
    My dealer has told me that the beo5 has the usual hidden service menu, full of counters and regulation possibilities...
    I suppose the access is via a key combination or something similar... Anyone?
    Santiago
  • 10-15-2007 12:13 PM In reply to
    Santiago,
    The most recent software version for the Beo5 is 1.20a and next time you get your Beo5 configuration updated at your dealer, their configuration tool will also update the processor software running in the Beo5.
    Your dealer is quite correct about the counters, it is easier to list the things it does not count. There is five pages of counters.
    Regards Keith....
  • 10-15-2007 12:42 PM In reply to
    You can review pictures of the Beo5 Service Counters HERE
    Regards Keith....
  • 10-15-2007 7:10 PM In reply to
    Keith Saunders:
    Santiago,
    Hello Keith !
    Last saturday morning I was at my dealer place for a meeting to pick up my brand new Beo5 and make the full on line configuration with him...everything was ok during the whole process and in the final phase the configuration tool software perfectly registered my personal config file in the official B&O server and in the dealer local computer too, after what it was trying to update de beo5 processor software several times without success Confused in that moment we both thought that simply there wasn't any firmware update available... that's why it has still the "old" 1.12a version.
    Maybe next time I walk to the shop I'll carry my beo5 for another update try...Hmm
    Thank you.
    Santiago
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
