Latest post 12-02-2007 9:07 AM by Peter. 12 replies.
Page 1 of 1 (13 items)
  • 10-01-2007 10:44 AM
    DVD2 region free?
    Hiyaz,
    Anyone know if the DVD2 can be region hacked?  Half of my DVDs are region 1 and the rest are region 2.  It's a side effect of moving to Europe, I guess.  The DVD2 is just a nice looking, rebranded Philips.  Maybe the region hack is the same?  That would be nice since Philips DVD players are ridiculously easy to set to region-free.
  • 12-02-2007 5:44 AM In reply to
    • tgodsk
    • Not Ranked
    • Joined on 12-01-2007
    • Posts 9
    • Gold Member
    Re: DVD2 region free?
    It can. Use the Philips code for DVDR7300H http://www.caliban.org/mt/archives/2006/04/dvdr7300h_uncri_1.html Replace 'Play' with 'Go' on Beo4. Wait 1-2 sec. between the first 'Go' and '1' or DVD2 will treat it as the command for 'System Menu'. Watch the digits on the player's LED display as you key them in. When finished, go to standby and the next time you turn the player on it's ready.
    HTH
  • 12-02-2007 5:58 AM In reply to
    I'll put this on site but what command do you use instead of Browser on the Beo4?
  • 12-02-2007 6:53 AM In reply to
    GO + 0 = Browser Smile
  • 12-02-2007 6:55 AM In reply to
    • tgodsk
    • Not Ranked
    • Posts 9
    • Gold Member
    The 'Browser' menu is the top-most menu on DVD2. Use 'Go' + '0' and verify that the LED on the player says 'BROWSER'.
  • 12-02-2007 7:06 AM In reply to
    Done!
  • 12-02-2007 7:36 AM In reply to
    I would be grateful for a region hack for the Mark III BV7-40 if there is anyone available. I have no idea what the Phillips model number is but if one of you does know that would be a great help. I too have 99% of my DVDs in Region 1.
    Thanks.
    Simon.
    "We can rebuild him. We have the technology." 7-40, 7-2, 9000, BS3, BC2, LC2, BC6000, Beo5
  • 12-02-2007 7:53 AM In reply to
    • tgodsk
    • Not Ranked
    • Posts 9
    • Gold Member
    Hi Peter, where did you put it?
  • 12-02-2007 8:18 AM In reply to
    Here!
    Is that OK?
  • 12-02-2007 8:20 AM In reply to
    The Beonic Man:
    Thanks.
    Simon.
    If 99% are Region 1, I would set it to Region 1. The DVD in the BV7 is probably a Pioneer so is not the same.
  • 12-02-2007 8:30 AM In reply to
    I wasn't aware I could set the region Peter?
  • 12-02-2007 8:32 AM In reply to
    • tgodsk
    • Not Ranked
    • Posts 9
    • Gold Member
    Perfect! Just curious Smile
  • 12-02-2007 9:07 AM In reply to
    The Beonic Man:
    Just checked - you will need your dealer to do this as it needs the service tool software. Shame - on the Avant, you can do it yourself!
