Latest post 09-29-2007 10:11 PM by James Chen. 6 replies.
Page 1 of 1 (7 items)
  • 09-25-2007 9:03 AM
    Beolab 4 cost
    Hi, does anyone know the retail price  ?
    Thanks alot
  • 09-26-2007 9:17 AM In reply to
    Re: Beolab 4 cost
    Just want to know if it is worth having friend bring a pair back when visiting states, retail price in where I live is around USD $1600.
  • 09-28-2007 9:58 AM In reply to
    Re: Beolab 4 cost
    There are 2 versions, the Beoolab 4 PC version without powerlink is 999$. You can order form amazon where they house the B&O store or get them at any apple store.
    The normal version, that has powerlink and that you can connect to Besounds and Beocenters is 300$ more I think. Both prices plus tax.
    JK
  • 09-28-2007 4:57 PM In reply to
    Re: Beolab 4 cost
    Thanks a lot JK, I'll have my friend buy a pair for me then.
  • 09-28-2007 7:12 PM In reply to
    Re: Beolab 4 cost
    Wouldn't do it assuming you are in UK. Not sure about warranty, plugs are different - voltage I think can be adjusted, you can get back the US taxes when you leave however they will slap the UK taxes on top when you enter the UK unless you smuggle them, after 20% UK tax on top of the 1300 you are pretty much there assuming 1600 is for the powerlink version
    Cheers
    JK
  • 09-29-2007 10:11 PM In reply to
    Re: Beolab 4 cost
    Thanks JK,
    I am in Taiwan, same voltage and plug, the price here is normally 10%~20% higher.
    Thanks again for you information.
    James
