Latest post 12-16-2007 4:22 AM by Peter. 10 replies.
Page 1 of 1 (11 items)
  • 09-23-2007 2:57 PM
    HELP- BEOSOUND 9000 PROBLEM READING DISCS- PAUSE
    Have read previous articles re: similar problem. Once unit is turned on works okay -goes to disc and starts "hunting" then shows "pause" in LED display. Once all tweaked seems to work okay for next few hours. Once it's been in standby a while ( hours) repeats same problem.
    Cleaned glass (inside and out),  Clamper assembly, interlock posts and channel in which clamper works/moves. Took back off unit and cleaned rear of clamper unit. It's a Mk3 so bit surprised got any probs. Used cleaning disc with small brushes. No joy. Anyone any last ideas before I line the pockets of my local B & O shop???
  • 09-23-2007 3:09 PM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: HELP- BEOSOUND 9000 PROBLEM READING DISCS- PAUSE
    Try cleaning the two small knobs on the lower front under the glass. If they are dirty the BS9000 will think there is a hand or something under the glass close to the discs and will pause.
  • 09-23-2007 3:11 PM In reply to
    Hi,  Thanks for getting back. Done this a couple of times but will give it another go . Can't hurt. thanks
  • 09-23-2007 6:20 PM In reply to
    No joy as expected. B & O shop here we come.
  • 09-24-2007 4:05 AM In reply to
    • archie
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    It's on all cd's ?
    DU BEAU, DU BON, DU BO.
  • 09-24-2007 9:52 AM In reply to
    Clean the laserlenz!
  • 09-24-2007 10:25 AM In reply to
    Re cleading the laser lens. I have done usig a dry soft brush. Still exhibits problem. Are you proposing that I use one that utilises a  slovent based liquid. If so which?
  • 09-24-2007 11:54 AM In reply to
    • archie
    • Paris
    • Posts 497
    have you read this http://forum.beoworld.org/forums/thread/15505.aspx
    it's seems to be a problem with the BS9000.
     what is the answer of the BO shop ?
  • 09-24-2007 12:27 PM In reply to
    Yes I read that one. Have done all the cleaning suggested. Mine is the Mk3. Spoke with B&O engineer who suggested using a liquid cleaner on the lens as a last resort. Failing that needs to be taken in for further investigation.
    What's annoying is once it's sorted itself out it works perfectly. Once it's been in standby half an hour or sotheproblem returns. Widsh it's pack up fully and I know what I'm doing with it then.( That's into the shop! )  Just keeps offering the potential of hope!!
  • 12-16-2007 2:22 AM In reply to
    • weidig
    • Not Ranked
    • Joined on 12-16-2007
    • Posts 1
    I discovered that the problem with my BeoSound 9000 is fogging over of the laser optics.  I live near the ocean, but my apartment is air conditioned.  Nonetheless, when I contacted a B & O technician, he suggested that I blow some warm air using a hair dryer into the CD reader head and see if that corrected the problem.  It did.  I also tried placing a heating pad on the glass over the reader head for an hour and that also worked.  Another course of action was to turn on the radio (on mute) for about an hour.  It allows the machine to heat up and drive away the condensation on the laser reader lens. That also works.  So, my advice is to keep your CD player WARM by turning on the radio for a while, letting the machine warm up, and then try playing your CDs.  This approach has saved me an enormous amount of grief let alone expense trying to pursue a solution that really is far more simple than an expensive repair.
     Paul Weidig, Honolulu, Hawaii
  • 12-16-2007 4:22 AM In reply to
    It is refreshing to hear that there are some disadvantages to living in Hawaii! Laughing
