Latest post 09-19-2007 5:16 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 09-16-2007 6:16 PM
    Soundsmith cartridge!
    Well, I broke down and bought the entry level cartridge from Soundsmith.  After I leveled the turntable, and set the tracking force with a scale, I sat down and put on Sade, Diamond Life.
    I have to say the sound was startling!  I never knew my BG 3000 had it in it!  Absoulutly fantastic sound!
    Guy
  • 09-17-2007 4:07 AM In reply to
    Re: Soundsmith cartridge!
    I agree. I do think they are better sounding than the originals.
  • 09-19-2007 4:59 AM In reply to
    • 1203
    • Not Ranked
    • Joined on 04-27-2007
    • Posts 25
    Hello,
    In my opinion the difference between for example SMMC4 and MMC4 is not that big if you have a relatively "new" MMC4, especially on the audio side. On the mechanical tracking side there is a bigger difference in favour of the SMMC4.
  • 09-19-2007 5:16 AM In reply to
    I have a SMMC20EN and the type of diamond used seems very different to the B&O MMC20EN. Far more like a CL in some ways. Agree about the tracking but in my case the sound is also much clearer and sibilance much less on some of my difficult recordings.
