Hi
I've been having discussions with B&O Technical regarding what I see as a bug with BeoMedia and what B&O see as a design feature. I'd be interested in your thoughts and comments.
I have BeoMedia 1 connected to my BV7. My BV7 has a full compliment of speakers attached, fronts, rears and a BL2. When I select PC from my Beo 4 the BV7 switches to Speaker 5 (as PC is seen as a video source). However for playing N.Music, the primary reason anyone would purchase BeoMedia 1 then I believe that Speaker 2 should be the default. B&O disagree stating that BeoMedia is a Video product.
To compound matters BeoMedia 1 does not support 5.1 audio in it's current form. Although there is a digital output apparantly it is PCM and the BV7 does not support PCM!
I think the Beo5 could help fix this issue with its macro function, i.e select BeoMedia and then a Macro runs to select speaker 2 - I'm waiting for B&O to get back to me on this.
Another bug I have discovered is that if you view a video on BeoMedia 1, which incidently you have to select the photo option to get at your videos and then go back to the main menu and select N.Music both audio sources (video and n.music) play together. Again as far as I am concerned this is a bug. B&O's view.... "this is how you should expect it to work"
When speaking to B&O about these issues I am told I am the first person to have made the above comments, I find this hard to believe!
I'm currently debating if I should return my BeoMedia and BV7 as not fit for purpose based upon the above..... this seems extreme but the combination of the issues and B&Os arrogance (the corporation not the individuals I have spoken to) about these being features not bugs has really wound me up.
I'm not sure how to set up a poll, but I think if a moderator could add one to this post it would be useful.
Greg
