Hi, I use Win XP Pro / SP3 (?) with Beoport. My PC is able to go into standby mode with Beoport.
But it's full of bugs. After waking up the PC Beoplayer has lost the external link sources like RADIO an CD (from my BS 9000) in the right menu bar. So after standby mode I have to click "setup" and "sources" and select them again. Very annoying...
Then: If you play an external source via Beoport (f.e. RADIO from the BS 9000), the PC can't go to standby because beoplayer is running.
Anyway. After all, I disabled the standby mode Ok, no problem since I work with the PC the whole day long...
cheers, Jens
