Latest post 09-14-2007 2:49 AM by kallasr. 0 replies.
Page 1 of 1 (1 items)
  • 09-14-2007 2:49 AM
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Video Master plus Speaerks and Audio Master plus speakers?
    Hello Forum,
    my setup is a BV-32 with BL8000/BL6000/Sub connected. Via Converter Type 1610 the TV is connected to a BC2500.
    Can I connect via Powerlink speakers to the BC2500 that can be switched on either in addition to the rest or (even better) all alone (TV connected speakers turned off then)?
    I got a Beolink Passive Unit which could serve as an amplifier for passive speakers that I want use in the above mentioned setup.
    Thanks for your support!
    Ralf
    PS: Background of this is: I am setting up a ethernet to masterlink system but instead of ml version I got the powerlink to ethernet cables...
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
