Latest post 09-12-2007 12:49 PM by Peter. 2 replies.
Page 1 of 1 (3 items)
  • 09-12-2007 6:42 AM
    Anyone installed a STB-C in an MX TV?
    I am in need of an installation manual ... there is not one in the archive.
     Thanks, Neil
  • 09-12-2007 7:11 AM In reply to
    Re: Anyone installed a STB-C in an MX TV?
    nobby:
     Thanks, Neil
    See if I can found mine. I install it into my MX4000 and it doesent work. They had big problem with STB in MX series
  • 09-12-2007 12:49 PM In reply to
    Look at the one for the AV9000. It includes the MX. Make sure you have the correct kit as the one I got had lots of bits missing and it was only because Terry the installer had all sorts of bits that we got it working.
