Latest post 09-08-2007 11:28 AM by Jez. 3 replies.
Page 1 of 1 (4 items)
  • 09-06-2007 3:32 AM
    Beogram connecting BV7
    hi , anybody please tell me , how can i hook a Beogram 6500 to the BV7 ?
    6500 has RIAA built in , but where should i plug it in ? any easy way ?
    please help . thanks .
    david
  • 09-07-2007 6:03 PM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Re: Beogram connecting BV7
    A number of options here. There is no DIN aux socket on the BV7 unfortunately.
    If you still have the DIN cable for the beogram get yourself a DIN to RCA cable. On the right side of the BV7 there is a connection for a video camera or like. This is more of a temporary solution.
    Alternately try an additional Scart to RCA connector which would allow you to connect the Turntable direct to a scart socket.
    In either case you assign the socket to a command.
    Do you have an audio system master linked?
    Beoaus.
  • 09-08-2007 10:51 AM In reply to
    hi beoaus ,
    thanks for your response .
    no . i don't have any link but have din--rca cable . will try your scart rca way , but which scart should i attach the beogram to ? and then , is it needed to set the source up ? how ?thanks again .
    regard
    david
  • 09-08-2007 11:28 AM In reply to
    • Jez
    • Top 500 Contributor
    • Joined on 06-13-2007
    • Posts 150
    Looking at the back of the BV7, on the right you have coax connections. With a din to coax cable this should be no problem, i've done it with my ipod before. Just add PC to the list function on Beo4 and PC in setup. Or go into the camera connection if you don't mind seeing the cable hanging out the side, also must add camera function to list button on Beo4.
