Latest post 09-05-2007 5:52 PM by SDB. 6 replies.
Page 1 of 1 (7 items)
  • 08-29-2007 9:37 AM
    • SDB
    • Not Ranked
    • Joined on 06-22-2007
    • Posts 31
    Is there a way to play a 12" disc at 45 rpm?
    I've got a BG4004 and a Beocenter 2200 ... I can't see how it can be done, but thought I'd ask here just in case I'm missing something.
     I have a Mobile Fidelity LP that's in the 12", 45 rpm format.
     Seems I've found the downside to automation ...
  • 08-29-2007 10:29 AM In reply to
    Re: Is there a way to play a 12" disc at 45 rpm?
    I haven't done this for a while on my 4002, but can't you hit the 45 selctor key on your 4004 when the tracking arm is in the air? I'm sure I've done this before, and therefore it has to be straightforward!
  • 08-29-2007 10:39 AM In reply to
    • SDB
    • Not Ranked
    • Posts 31
    DOINK!!
     I'm going to try it!
    The deck's not set up at the moment, but soon will be.
    Thanks!
  • 08-29-2007 1:25 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    I'm pretty sure John's rgiht. It's certainly the way to do it with the later tangential decks and I'm pretty well 99% sure it's the same with the beocenter 2200.
    Chris.
  • 08-29-2007 3:28 PM In reply to
    • Teddy_fr
    • Not Ranked
    • Joined on 04-16-2007
    • near Angoulême, France
    • Posts 250
    START << and 45
    I just have done it on my Beogram 6000 and it works fine!
    Enjoy your Beogram 4004!
    Marc Smile
  • 08-29-2007 10:29 PM In reply to
    • Piaf
    • Top 150 Contributor
    • Joined on 07-08-2007
    • Victoria, British Columbia
    • Posts 409
    There is NO problem changed speeds with a Beogram 4002 or 4004, just push the speed button, and you are there.
    Conversely, if you have a 7” record that requires 33 1/3, just press the 33 button and you will be at the correct speed.
    Everything in life should be this easy! Enjoy your Beogram 4004…. I certainly do mine! Big Smile
    Jeff
  • 09-05-2007 5:52 PM In reply to
    • SDB
    • Not Ranked
    • Posts 31
    Thanks, everyone!
    And to all of you who  have 4004's, I have a question: Can I have your dustcover?
