Latest post 08-26-2007 3:56 AM by joeyboygolf. 8 replies.
Page 1 of 1 (9 items)
  • 08-26-2007 12:46 AM
    BC 9500 Speaker selection !!!!!!!!!!!!!
    Nothing on the site about this....please help anyone..
     Is there a way to select with remote or manual....between Speaker 1 and 2 ????
    If so......how does that relate to Powerlink 1 and 2....
    Specifically.......can I run Passive speakers off Speaker 1.......and  Active speakers off Powerlink 2 and......choose between them???? ...ie..a set of speakers in one room and another set in another with control between them...
    THanks guys...K
  • 08-26-2007 1:24 AM In reply to
    Re: BC 9500 Speaker selection !!!!!!!!!!!!!
    Beolink Active or Passive is designed to allow control of extra speakers in another room.
    Regards Graham
  • 08-26-2007 1:29 AM In reply to
    I understand Graham...but what i'm wondering is....
    With the BC 9500 ONLY...if I have Passives connected to the SPEAKER 1 outlet and Active speakers connected to the Powerlink 2....
     Can I use the remote and switch on 1 or 2 or both togther..???
    THanks. K
  • 08-26-2007 1:36 AM In reply to
    Both will come on together, then you can press MUTE on the remote or front panel to stop Speakers 1 and the powerlinks.
    Regards Graham
  • 08-26-2007 2:22 AM In reply to
    Thanks Graham...so can I play them INDEPENDENT???????
  • 08-26-2007 2:39 AM In reply to
    Only Passive Speakers 2 will play if you press MUTE.
    Regards Graham
  • 08-26-2007 2:40 AM In reply to
    Thanks !!!!  Exactly what I was looking for......
  • 08-26-2007 2:43 AM In reply to
    Graham...once I press Mute....and stop the other speakers.......will the volume up and down control the Speaker 2's???
    Much appreciated...!!
  • 08-26-2007 3:56 AM In reply to
    Yes.
    Regards Graham
