Latest post 04-13-2009 10:54 AM by ouverture. 12 replies.
Page 1 of 1 (13 items)
  • 04-18-2007 10:50 AM
    Serial number/Age relationship
    Anyone remember how the serial number (first two digits)/Age of product relationship works?
    I had it from a post on the old forum but of course it is no longer available.
    Regards Graham
  • 04-18-2007 11:31 AM In reply to
    • Graeme
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Aberdeenshire Scotland
    • Posts 194
    Re: Serial number/Age relationship
    LaughingLaughing I was about to ask something similar.
    Can we have a page of popular older equipments serial numbers and the age relating to them?
    Graeme
    Cheers Graeme
  • 04-19-2007 7:57 AM In reply to
    Anyone?
    Regards Graham
  • 04-19-2007 8:43 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Here you go!
    The first two numbers relate to the approximate year of manufacture. If a product was made just before everyone went home on Dec 31st 2003, it will be one digit out from a 2004.. Huh?
    Okay..
    09 - 1994
    10 - 1995
    11 - 1996
    12 - 1997
    13 - 1998/99
    14 - 2000
    15 - 2001
    16 - 2002
    17 - 2003/04
    18 - 2004/05
    19 - 2006/07->
    Hope this helps
    Lee
    Filed under: ,
  • 04-19-2007 8:56 AM In reply to
    Hi there,
    @ Lee - This is exactly the sort of info I used to store in the "my space" or "my controls" area in the old Beoworld, that I lost in the upgrading. Do you think there is a way we will be able to retreave this ? Cheers and congratulation again for the new site !
    Christophe
  • 04-19-2007 9:03 AM In reply to
    Many thanks Lee
    Regards Graham
  • 04-19-2007 10:33 AM In reply to
    • Tom
    • Top 25 Contributor
    • Luxembourg
    • Posts 3,175
    the serial number of my besound3 begins with 94. Indifferent
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 04-19-2007 1:13 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Some products differ, but it will be in there!
    Some V8000's and DVD1's have the Serial (for example) 9148345432 - but you just need to ignore the 9 at the beginning..
    Lee
  • 04-20-2007 6:36 PM In reply to
    Is there any chance we could have an article written up covering this topic and posted on the main site?
    Nicholas
  • 04-20-2007 6:47 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Yes, of course.
    I am currently sorting out 'teething issues' which are now pretty much done, and after that i will be spending 1-2 days a week full time updating articles, news, FAQ's etc - as will Steve. This ought to create a pretty comprehensive database over the months/years!
    Lee
  • 04-23-2007 4:49 AM In reply to
    • sveifors
    • North of Norway
    • Posts 145
    Thanks, but I have  one question. How far back does this go? It would mean that 1986 will have 01, but what about earlier than this?
    Sveifors Always look on the B & O side of life
  • 04-13-2009 4:44 AM In reply to
    HI
    Sveifors
    Try to look on www.beocentral.com under audio intregreted systems
    regards
    jan
  • 04-13-2009 10:54 AM In reply to
    thanks Lee, that is great to have handy, what about prior to 1986 ??
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
