Latest post 08-20-2007 6:14 AM by ProGram. 1 replies.
Page 1 of 1 (2 items)
  • 08-19-2007 5:58 PM
    beomaster 3300 power issue
    hi all,
    below is a *bump* from the general forum. i decided to repost it here in hopes that someone might have some advice.
    just came into possession of a bm3300. it will not power up. checked the fuses, everything is fine and clean. i could find nothing obvious... any thoughts?
    i just had it apart again out of frustration -same story. i get nothing out of it -no standby light -nothing. i have the service manual, but was hoping that someone might have a listable methodology as to testing.
    as always, thx in advance!
    • B&o bottle opener
    Filed under:
  • 08-20-2007 6:14 AM In reply to
    • ProGram
    • Top 500 Contributor
    • Joined on 06-01-2007
    • NRW, Germany
    • Posts 145
    Re: beomaster 3300 power issue
    Hi Jeff!
    You're lucky having a manual. I do not and cannot find in beoworlld either. Best method to test: find out the power-supply:  Usually, it is running all time, so you should measure a resistance in the powerlead. (some hundred ohms; is there a primary on-off-switch?). Just tip at the mains-plug. If there is no value, the transformer is broken. To be sure, you can measure the transformer itself. In most cases there is a built-in thermo-fuse and sometimes, it can be replaced. If the transformer is working, go on looking for the supply- voltages eg.: 12V, 5V, those for the controller. Maybe a rectifier?...
    Good luck !
    Chris
