Latest post 04-19-2007 4:54 PM by Iconic-AV. 5 replies.
Page 1 of 1 (6 items)
  • 04-18-2007 7:28 AM
    free beovision mx 4000 replacment screen
    by total accident i have just found a way to replace your plastic contrast screen if it has been scratched
    simply pop it out and reverse it, mine was quite badly scratched and now looks as good as new, cant see the scratches even close up
    it may work on other models with the same plastic screen
    thought id share my find with everyone
    jayCool
    jason
  • 04-18-2007 1:26 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: free beovision mx 4000 replacment screen
    What model number is yours please (I want to check if I have a plastic or glass screen!)?
  • 04-18-2007 1:42 PM In reply to
    mine is type 33/23 mkll
    not sure if there is a list of which models have glass or plastic, as it is quite hard to tell from appearance untill you remove it
    jay
    jason
  • 04-18-2007 1:58 PM In reply to
    • GSHaigh
    • Top 500 Contributor
    • North West UK
    • Posts 163
    There was someone selling replacement screens on ebay.  I ordered one, but it's not arrived yet.  Mine has a slight chip at the top,  I'll let you know how I get on.
    Greg
  • 04-19-2007 4:11 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Another question please  - how do you remove it !!
  • 04-19-2007 4:54 PM In reply to
    Xseries:
    i must admit i just put my fingernail behind the notch just over bang and olufsen logo and gently pulled (ah-ha the glass ones may not have this)Idea
    although i dont recommend you follow my poor example incase you cause some damage or yours is glass
    im sure there is someone reading who knows the correct (safe) way to remove it
    good luck
    jay
    jason
