Latest post 09-23-2007 8:47 AM by marcus_m. 20 replies.
Page 1 of 1 (21 items)
  • 08-16-2007 11:49 AM
    CAT 6 STP Shielded Jacks (marcus please)
    Hi Anyone....and Marcus..I know you've got lots of experience with this....
     I've bought my CAT 6 STP cable now i'm buyig wall jacks...will these work??
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=260148217399&ssPageName=STRK:MEWA:IT&ih=016
    THanks
  • 08-16-2007 2:20 PM In reply to
    Re: CAT 6 STP Shielded Jacks (marcus please)
    Hi Keith,
    if we suppose that the blank wires on the back are for the shield connection, yes they will work. I tend to recommend fully shielded ones, but haven't seen them on ebay, so go for these.
    If you experience ML problems, then connect the pink and the blue/white cable at the unit where you experience problems. I had probs with my BV7 after connecting the BV1L - shortcut of pink and blue/white does the trick ;)
    Good luck
    Marcus
  • 08-16-2007 4:39 PM In reply to
    Hi Marcus,
     I'm looking for fully shielded plugs and jacks now.
    Do they make a fully shielded splitter so I don't have to use a ML distribution box??
     Did you ever do a play by play on this coding for wiring?? Sorry if i missed it..ie. what color to what color../?
    Thanks, Keith
  • 08-16-2007 4:48 PM In reply to
    marcus_m:
    Hi Keith,
    Good luck
    Marcus
    Hi Frank Rizzo
    If you use the IHC/? cable we talked about some weeks ago the Pink and B/white is shortcut-ed
  • 08-17-2007 11:54 AM In reply to
    Hi Keith,
    here is the color coding I used (please check if the factory made homelink cables have the same color/pin coding!!!!):
    ML                Cat7         pin
    w/or              w/or          1
    or                 or             2
    w/gn             w/gn         3
    bl                 bl             4
    pi                 w/bl          5
    gn                gn            6
    w/rd             w/bn         7
    rd                bn            8
    To be honest, my "junction boxes" are not shielded at all :o
    I don't think it is necessary to look for fully shielded jacks, if you have a bad feeling with tha half shielded ones use some metal film to cover them.
    Marcus
  • 08-17-2007 3:00 PM In reply to
    Hi Marcus, Thanks....
    I thought the Shielding was a ground that was necessary to run through the entire system withouth interruption???
    K
  • 08-19-2007 2:04 PM In reply to
    Hi Keith,
    yes, you're right, but the junction box must not necessarily be shielded, you can also connect the shielding gasket of the cables with some kind of terminal strip.
    Marcus
  • 08-19-2007 2:08 PM In reply to
    Great Marcus...just 2 more questions...please...
     1) On the above description of Powerlink (MK II) to CAT 6.....which one connects to the "shielding" and drain wire???
    2) Could you post a similar schematic for Masterlink??
    Marcus, you've been a life-saver on this project....
    Thanks a TON !!!  Keith
  • 08-21-2007 5:20 AM In reply to
    Hi Keith,
    the color table I posted is for Masterlink, not Powerlink!
    For Powerlink connection I used original PL cables, so I'm sorry that I can't be of much help with this topic.
    Marcus
  • 08-22-2007 9:20 PM In reply to
    Hi again Marcus and others involved in these projects.
     Marcus, I have been looking for a distribution box that is shielded. One that will take 1 input in and give 4 or 8 out to service the house. I can't find one....
    Since our masterlink needs 8 wires PLUS the ground with "drain" wire....this must connect "THROUGH" the distribution box.....yes???? or am I crazy.....???
    THanks.
  • 08-23-2007 9:21 AM In reply to
    help...thanks..
  • 08-23-2007 2:09 PM In reply to
    For the box I did use a non shielded plastic box, normaly used for house wiring. I connected the cables with small connectors type 243 from a company called wago. For the shielding of the cat7 cables I used connectors type 222. Very simple but working good ;-)
    Marcus
  • 08-24-2007 12:35 AM In reply to
    Thanks Marcus.>!!!!!!!!!!!!!!!!
  • 08-24-2007 3:08 PM In reply to
    Great M...could be so kind to do the code for the Powerlink MK II the way you did the Masterlink...My tech guy loves it...
    Thanks 2 tons Marcus...K
  • 09-21-2007 7:09 PM In reply to
    CAT 6 STP POWERLINK (marcus please)
    Hi Marcus,
     Thanks for all the help....i've sent on this ML code to the guy making my cables...
    Could you please give a POWERLINK code for PL to CAT 6 STP????
    Much appreciated..
     K
  • 09-22-2007 2:58 AM In reply to
    Re: CAT 6 STP POWERLINK (marcus please)
    Hi Keith,
    sorry, but for Powerlink I used the B&O cables. Maybe there's another member here that has the Lexcom cables and can give some advice?
    Cheers
    Marcus
  • 09-22-2007 10:43 AM In reply to
    Thanks Marcus..
     QUESTION>>>>  CAN, I use the CAT 6 STP for the POWERLINKS??????
     WILL this work???????????
    THanks again..
    K
  • 09-22-2007 5:12 PM In reply to
    TTT....for Marcus...
  • 09-23-2007 3:16 AM In reply to
    Frank Rizzo:
    Sorry Keith, I don't know if it will work properly..... and without experience I won't give any advice.
    Marcus
  • 09-23-2007 4:06 AM In reply to
    THanks Marcus..I understand....
     Do you think it would work????
    THanks, K
  • 09-23-2007 8:47 AM In reply to
    As Lexcom offers this system for some years now, it has to work somehow, but I don't know which wires they use to achieve a proper shielding.
    Marcus
