        1st March February 2012
	    Latest post 02-27-2012 11:45 AM by Step1 . 49 replies.
									                 AlexJoined on 04-16-2007Bath & Cardiff, UKPosts 2,990 |
										    Re: Beolink 1000 versions
										    Yes, they do. I believe you can still get the BeoLink 5000 as well...  Weekly top artists:
									                 Jandyt
 Joined on 04-01-2007Clitheroe, Lancashire, UKPosts 13,004 |
										    Are you sure Alex?I believe you can get the 5000 but not so sure about the 1000.
 Andy T. |  |
										    I'm pretty sure, yes. I may be wrong though, but I only say that because you've put doubt in my mind!    Weekly top artists:
									                 GerdJoined on 04-20-2007GermanyPosts 523 |
										    Yes, the 1000 is still available, the 5000 not! |  |
										    Generally though, you would want to go for the Beo4 over the 1000. The 1000 is still a fantastic remote, and IMO, better than anything from any other manufacturer, while the Beo4 is more suited to more recent B&O kit, particularly with the LIST menu.  Weekly top artists:
									                 Jandyt
										    Extremely robust, the Beolink 1000.You can drop it off an eight storey building and absolutely guarrantee that it will still function perfectly!
      Sometimes, after they land, they don't always work. Andy T. |  |
									                 Medogsfat
 Joined on 02-21-2007*Moderator* Leeds, YorkshirePosts 4,045 |
										     Alex: Generally though, you would want to go for the Beo4 over the 1000. The 1000 is still a fantastic remote, and IMO, better than anything from any other manufacturer, while the Beo4 is more suited to more recent B&O kit, particularly with the LIST menu.
 Absolutely right Alex - the Beo4 is certainly more suited to later B&O products whereas the BL1000 suits pre mid 90's equipment better, I still prefer the BL1000 over any remote for every day use, probably because I'm so familiar with it. Fantastic piece of design and probably my all time favourite "must have" item and handy if you are doing some DIY and can't find a hammer The use of metaphors should be avoided like the plague. They're like a red rag to a bull to me. |  |
									                 deaddruidJoined on 05-24-2007Malvern, WorcestershirePosts 247 |
										    Thank you for all the replies, guys. This is the first post I've started which has gone over one page! I still don't know quite which remote I've got, but I take the point that its 3+, that all 3+ have the same functionality, and I don't need to know more than that. I'm becoming more curious, however. I had assumed that all button presses were transmitted, and that the receiver took note of use of the SHIFT key, to work out what is going on. However, since SHIFT functions seem to be different on each of mk1, mk2 and mk3, it must be the remote which converts the SHIFT+<another key> into a code to transmit. Am I making sense, or misunderstanding? Mark  |  |
									                 henrikJoined on 04-16-2007Stockholm, SwedenPosts 299 |
										     deaddruid:I'm becoming more curious, however. I had assumed that all button presses were transmitted, and that the receiver took note of use of the SHIFT key, to work out what is going on. However, since SHIFT functions seem to be different on each of mk1, mk2 and mk3, it must be the remote which converts the SHIFT+<another key> into a code to transmit. Am I making sense, or misunderstanding? Mark
 I think you're right. I don't remember what the situation was, but came to the same conclusion once when I had to use an older bl1000 |  |
										    No, this isn't the case, shift + A.Tape actually produces a different resultant signal to a simple A.Tape command. Press shift, with your hand completely covering the IR transmitter at the end of the BeoLink, and press shift, then uncover your hand and press A.Tape. A.Tape 2 is still activated, even though the BeoMaster/Center didn't receive the SHIFT command. The BeoLink 1000 is actually pretty smart under the hood, smarter than you would expect it to be just from appearances.  Weekly top artists:
										     Alex:No, this isn't the case, shift + A.Tape actually produces a different resultant signal to a simple A.Tape command.
Yes, that was my and Mark's point ;-) |  |
									                 The Stig - ver. 1.7Joined on 06-20-2007Posts 898 |
										    We cut test this! If somebody has a LC2 and a BL1000 mrk3+, then press shift + link and see if it controls the light? I think the shift command maybe only, is setting a bit in the bit stream it's sends! F.ex A.tape                00101010 shift + A.tape      10101010 and A.tape                00101010 link + A.tape       01101010 would be nice to know  |  |
									                 oPossumJoined on 04-16-2007Posts 3 |
										    Shift changes the key code (last 2 digits), link sets a bit...  11:00191  A.TAPE 11:00194  A.TAPE2 (SHIFT + A.TAPE) 11:10191  LINK + A.TAPE 11:10194  L-A.TP2 (Beo4) 11:00091  AV + A.TAPE (Beo4) number_of_bits:data (both in hexadecimal)   |  |
									                 rabbleJoined on 07-13-2007SwitzerlandPosts 75 |
										    I've just acquired a Beosystem 7000 that came with a beolink 1000. Most of the controls are quite simple to do except for controlling the radio functions. I can't seem to search for new station and I can't display RDS or clock, all I can do is use the stations that were previously programmed. Does someone know what the commands are to do this, or do I need a Beolink 7000?   Andrew |  |
									                 Jandyt
										    Hi Rabble.The Beomaster does not display RDS or the clock, sorry.
 RDS and the clock are displayed on Beolink 7000.
 As for radio tuning, it's easy with Beolink 1000
 Radio   goto    up or down button.
 Once you get the channel you want
 Store   7    store (Choose your own number)
 Come back if you have any problems.
 Andy T.
										    Hi Andy,  thanks for the info. it seems to work, however I can't seem to display the frequency of the channel. Is this something also only avail. on the Beolink 7000. I thought that the main difference between the 6500 and the 7000 was that the RDS would display on the receiver. If that's not possible then what's the difference? Cheers Andrew  |  |
									                 Jandyt
										    No, you can't see the frequency on the Beomaster, only on the Beolink7000.However, if you know the frequency you're after, you can enter it in four figures on FM only.
 Radio    Goto    1015    store    7    store   =  101.5 FM stored on channel 7As soon as you press Goto, it should say "F" on your Beomaster.
 If you want change to AM, then Radio    Goto    Shift    Sound    then immediately up or down button before it slips back to FMIt should say "A" on the Beomaster..
 I am not 100% sure but I think the only two differences between 6500 and 7000 is that
 6500 only available in White or Aluminium 7000 also available in Black and mirror finnish
 7000 has RDS decoder whereas 6500 hasn't.
 RDS decoder is not much use unless you have a Beolink 7000. However, if I remember correctly, Channel name and frequency can be seen on a linked in TV like LX4500.    Radio    AV    Radio    Menu   springs to mind but don't quote me on that!
 Andy T.
										    The RDS module can also be fitted to either later BeoMaster 6500s, or all 6500s...  Weekly top artists:
										    Hi Andy,  thanks for all your help, at least now I can listen to radio and not just static. I guess I'll be searching for a Beolink soon, as the only reason I chose the 7000 over the 6500 was for the RDS. Regards  Andrew     |  |
									                 Step1
 Joined on 07-06-2008ManchesterPosts 961 |
										    Does anyone know if you can switch loudness in/out with a mk3 control? I can achieve this with my mk2 using a shift command but not on my mk3...   *I should add this is with my master 5500... |  |
