Latest post 02-27-2012 11:45 AM by Step1. 49 replies.
Page 2 of 2 (50 items) < Previous 1 2
  • 08-17-2007 7:40 AM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Re: Beolink 1000 versions
    MK6!! Never hear of that one. Does B&O still make the Beolink 1000?
    Durban South Africa
  • 08-17-2007 2:43 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    Yes, they do. I believe you can still get the BeoLink 5000 as well...
     Weekly top artists:
  • 08-17-2007 2:58 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Are you sure Alex?
    I believe you can get the 5000 but not so sure about the 1000.
    Andy T.
    Poor me, never win owt!
  • 08-17-2007 3:11 PM In reply to
    • Alex
    • Posts 2,990
    I'm pretty sure, yes. I may be wrong though, but I only say that because you've put doubt in my mind! Laughing
     Weekly top artists:
  • 08-17-2007 4:09 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Yes, the 1000 is still available, the 5000 not!
  • 08-17-2007 4:18 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    They never advertise it though? Such a popular remote as well. Never in any brochures.
    Durban South Africa
  • 08-17-2007 4:56 PM In reply to
    • Alex
    • Posts 2,990
    Generally though, you would want to go for the Beo4 over the 1000. The 1000 is still a fantastic remote, and IMO, better than anything from any other manufacturer, while the Beo4 is more suited to more recent B&O kit, particularly with the LIST menu.
     Weekly top artists:
  • 08-17-2007 6:26 PM In reply to
    • Jandyt
    • Posts 13,004
    Extremely robust, the Beolink 1000.
    You can drop it off an eight storey building and absolutely guarrantee that it will still function perfectly!Yes -  thumbs up
    Sometimes, after they land, they don't always work.
    Andy T.
  • 08-17-2007 6:48 PM In reply to
    LaughingLaughingLaughingLaughing
  • 08-17-2007 8:07 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Alex:
    Absolutely right Alex - the Beo4 is certainly more suited to later B&O products whereas the BL1000 suits pre mid 90's equipment better, I still prefer the BL1000 over any remote for every day use, probably because I'm so familiar with it. Fantastic piece of design and probably my all time favourite "must have" item and handy if you are doing some DIY and can't find a hammerLaughing
  • 08-20-2007 4:28 PM In reply to
    • deaddruid
    • Top 500 Contributor
    • Joined on 05-24-2007
    • Malvern, Worcestershire
    • Posts 247
    Thank you for all the replies, guys. This is the first post I've started which has gone over one page!
    I still don't know quite which remote I've got, but I take the point that its 3+, that all 3+ have the same functionality, and I don't need to know more than that.
    I'm becoming more curious, however. I had assumed that all button presses were transmitted, and that the receiver took note of use of the SHIFT key, to work out what is going on. However, since SHIFT functions seem to be different on each of mk1, mk2 and mk3, it must be the remote which converts the SHIFT+<another key> into a code to transmit.
    Am I making sense, or misunderstanding?
    Mark
  • 08-20-2007 4:57 PM In reply to
    • henrik
    • Top 200 Contributor
    • Stockholm, Sweden
    • Posts 299
    deaddruid:
    Mark
    I think you're right. I don't remember what the situation was, but came to the same conclusion once when I had to use an older bl1000
  • 08-20-2007 6:46 PM In reply to
    • Alex
    • Posts 2,990
    No, this isn't the case, shift + A.Tape actually produces a different resultant signal to a simple A.Tape command.
    Press shift, with your hand completely covering the IR transmitter at the end of the BeoLink, and press shift, then uncover your hand and press A.Tape. A.Tape 2 is still activated, even though the BeoMaster/Center didn't receive the SHIFT command.
    The BeoLink 1000 is actually pretty smart under the hood, smarter than you would expect it to be just from appearances.
     Weekly top artists:
  • 08-21-2007 3:22 AM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    Alex:
    Yes, that was my and Mark's point ;-)
  • 08-21-2007 8:32 AM In reply to
    • Alex
    • Posts 2,990
    Oh shush you Stick out tongue It was too late at night... Laughing
     Weekly top artists:
  • 08-21-2007 6:53 PM In reply to
    We cut test this! If somebody has a LC2 and a BL1000 mrk3+, then press shift + link and see if it controls the light?
    I think the shift command maybe only, is setting a bit in the bit stream it's sends!
    F.ex
    A.tape                00101010
    shift + A.tape      10101010
    and
    A.tape                00101010
    link + A.tape       01101010
    would be nice to know Smile
  • 08-22-2007 4:20 AM In reply to
    Shift changes the key code (last 2 digits), link sets a bit...
    11:00191  A.TAPE
    11:00194  A.TAPE2 (SHIFT + A.TAPE)
    11:10191  LINK + A.TAPE
    11:10194  L-A.TP2 (Beo4)
    11:00091  AV + A.TAPE (Beo4)
    number_of_bits:data (both in hexadecimal)
  • 08-23-2007 6:12 AM In reply to
    • rabble
    • Not Ranked
    • Joined on 07-13-2007
    • Switzerland
    • Posts 75
    I've just acquired a Beosystem 7000 that came with a beolink 1000.
    Most of the controls are quite simple to do except for controlling the radio functions.
    I can't seem to search for new station and I can't display RDS or clock, all I can do is use the stations that were previously programmed.
    Does someone know what the commands are to do this, or do I need a Beolink 7000?
    Andrew
    Andrew
  • 08-23-2007 12:08 PM In reply to
    • Jandyt
    • Posts 13,004
    Hi Rabble.
    The Beomaster does not display RDS or the clock, sorry.
    RDS and the clock are displayed on Beolink 7000.
    As for radio tuning, it's easy with Beolink 1000
    Radio   goto    up or down button.
    Once you get the channel you want
    Store   7    store (Choose your own number)
    Come back if you have any problems.
    Andy T.
  • 08-23-2007 12:15 PM In reply to
    It's still possible to get a brand new BL5000 and BL1000  Smile
  • 08-23-2007 12:46 PM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    Hi Andy,
    thanks for the info. it seems to work, however I can't seem to display the frequency of the channel.
    Is this something also only avail. on the Beolink 7000.
    I thought that the main difference between the 6500 and the 7000 was that the RDS would display on the receiver.
    If that's not possible then what's the difference?
    Cheers
    Andrew
    Andrew
  • 08-23-2007 4:36 PM In reply to
    • Jandyt
    • Posts 13,004
    No, you can't see the frequency on the Beomaster, only on the Beolink7000.
    However, if you know the frequency you're after, you can enter it in four figures on FM only.
    Radio    Goto    1015    store    7    store   =  101.5 FM stored on channel 7
    As soon as you press Goto, it should say "F" on your Beomaster.
    If you want change to AM, then
    Radio    Goto    Shift    Sound    then immediately up or down button before it slips back to FM
    It should say "A" on the Beomaster..
    I am not 100% sure but I think the only two differences between 6500 and 7000 is that
    6500 only available in White or Aluminium 7000 also available in Black and mirror finnish
    7000 has RDS decoder whereas 6500 hasn't.
    RDS decoder is not much use unless you have a Beolink 7000. However, if I remember correctly, Channel name and frequency can be seen on a linked in TV like LX4500.    Radio    AV    Radio    Menu   springs to mind but don't quote me on that!
    Andy T.
  • 08-23-2007 5:12 PM In reply to
    • Alex
    • Posts 2,990
    The RDS module can also be fitted to either later BeoMaster 6500s, or all 6500s...
     Weekly top artists:
  • 08-24-2007 4:16 AM In reply to
    • rabble
    • Not Ranked
    • Switzerland
    • Posts 75
    Hi Andy,
    thanks for all your help, at least now I can listen to radio and not just static.
    I guess I'll be searching for a Beolink soon, as the only reason I chose the 7000 over the 6500 was for the RDS.
    Regards
     Andrew
    Andrew
  • 02-27-2012 11:45 AM In reply to
    • Step1
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Does anyone know if you can switch loudness in/out with a mk3 control? I can achieve this with my mk2 using a shift command but not on my mk3...
    *I should add this is with my master 5500...
    Olly.
