Latest post 08-16-2007 4:28 AM by Medogsfat. 4 replies.
Page 1 of 1 (5 items)
  • 08-15-2007 3:28 PM
    REFOAMING PENTAS
    Just found this on Ebay..... i've already paid for new midranges....but i'm going to keep my old ones and try to re-foam them....
     Anybody tried this??
     http://cgi.ebay.com/Repair-kit-for-Bang-Olufsen-Beolab-Penta-100-fit_W0QQitemZ280138016146QQihZ018QQcategoryZ14993QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • 08-15-2007 3:45 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: REFOAMING PENTAS
    Yes,
    I've used these exact ones and they are an excellent fit. The fit of the foams is of course important, but the correct fitting method is even more so.
    There is an excellent ongoing thread in the workbench section which, up to present, is showing exactly the correct way of doing this.
    Chris.
  • 08-15-2007 3:47 PM In reply to
    Look here at Andy's job (Still in progress)
  • 08-15-2007 3:54 PM In reply to
    Thanks guys....i see that the other BnO speaker was done....has anyone done these on the Penta Midranges...(i know technique is technique)...i'm just wondering if it's been done by any here...
    Thanks,,k
  • 08-16-2007 4:28 AM In reply to
    • Medogsfat
    • Posts 4,045
    As I mentioned earlier Frank - I have used these.
    The technique is exactly the same for all foam surrounds except you have far less tolerance when centering the coils (due to the small size which gives less "play" on the surrounds) and may require shimming in some cases. The smaller the driver = the more accuracy & patience required.
    Chris.
