Hi
I just brought myself a second hand BV5 Mark I and wondering if its worth while to get the software update to 10.3 which I think its the last software that it can be updated for this type. Does it need any chip or its just an software update?
Plus on the sound menu under type, it only gives one type which on my is Dolby 3 stereo, does it give you a choice or its this correct?
Davidson
