Latest post 08-14-2007 8:19 AM by kawo. 6 replies.
Page 1 of 1 (7 items)
  • 08-13-2007 4:05 PM In reply to
    Re: Is is possible to haggle discounts?
    http://www.beoworld.org/article_view.asp?id=192
    here you go.
     I think for some products, mostly when they are about to be replaced you can get a discount. I bought in the US a pair of BL3 and BL2 and got few % off when I asked if they would make me a package deal, initially I had only looked at the BL3.
    Good luck.
    JK
  • 08-13-2007 4:25 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Try 2 or 3 dealers in your locality (Dealer section on the main site), and see who comes up with the best discount.  Once you have the best discount, call the other 2 dealers and see if they want to beat it.
    After that, make your choice depending on who can offer the best deal.  Remeber they have to make a profit, as well as you wanting a good deal. Meet in the middle and if both parties are happy, then it's happy days!
    Lee
    Big Smile
  • 08-13-2007 5:14 PM In reply to
    Also remember it's not just all about the price. If you can build a good relationship with a good dealer (and get a good price) then the future should be set for later purchases/support etc. So find someone you can really get on with and build from there.
  • 08-14-2007 5:53 AM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    over here, most dealers give you some % if you ask for, especially if you pay before delivery or if you buy some of the more expensive products. But tobeyone is right when saying that the passion for B&O lasts for all of your life, so it is important to find a dealer you get along very good, so the price is not the most important thing to ask for.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 08-14-2007 8:19 AM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    Fully agree, pricing is not all (but for sure important). If you go with products which may need some service or updates from time to time (like a Beosystem 3 in a BV7, 9 or BV4) you need a supportive dealer! Or when it comes down to link B&O products, attach 3rd party ones you may need a helping hand as well.
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
