Latest post 08-08-2007 4:56 PM by MoglesMac. 3 replies.
Page 1 of 1 (4 items)
  • 08-08-2007 1:21 PM
    VX7000 on a Sony TV
    Hello,
    A VX7000 VCR "landed" in my lap, only coz i was after the Beolink 5000 that came with it and now i wanna see if it works in order to eventually sell it. I can play tapes with the playbutton at front of VCR and then eject the tape also with button on front of VCR. All seems to work since i get a nice picture via a SCART to my Sony-TV.
    However its completely dead when i try to use the Beolink 5000 (was in 2-way mode) or even a old Beolink 1000 (both works 100%). The VCR are the 2-way-version according to typenumber. Do i need a Bang&Olufsen TV in order to use remote? I have the manual but not the "set-up-papers".
    Cheers
    MoglesMac
  • 08-08-2007 1:43 PM In reply to
    • Jesper
    • Not Ranked
    • Joined on 04-20-2007
    • Denmark
    • Posts 17
    Re: VX7000 on a Sony TV
    Hi
      I think you definitely need a B&O TV til control your VX7000 via the scart connection, VX7000 does not have an IR-eye, neither does the VX4500/5000.
    /Jesper
  • 08-08-2007 2:06 PM In reply to
    Though it is possible to hard wire an IR receiver in. There was an option to do this - though goodness only knows if any parts are still available!
  • 08-08-2007 4:56 PM In reply to
    Thanx Jesper, I really suspected that... but was unsure.
    I also belive there was probobly a special kit in order to make it work on 3rd party TV as Peter is saying since some of the sentences in the manual makes me suspect that but i guess i will have to test it on a B&O TV (a friend of mine got one).
    Cheers for the help
    MoglesMac
    Sweden
