Yes there is a fuse inside it, I have seen some where the standby transformer stopped working this is maybe the problem!!
Loosen the speaker cover by pressing in on it and pull the side of it outward, do this from top to bottom in both sides. then you can pull the cover upward and of. the amp. is placed at the bottom.
